[Gdal-dev] Re: Gdal-dev Digest, Vol 36, Issue 25
Michael Sumner mdsumner at utas.edu.au
Sun May 13 19:18:03 EDT 2007
Hello, you would certainly want to subdivide the original file into the
zones you wanted to convert to UTM.
You would also want to remove the extreme north and south regions from
the longlat data as Mercator is not defined at the poles.
Cheers, Mike.
> Subject:
> [Gdal-dev] shape file of the world: lat/lon to utm
> From:
> "Sanges Michele" <Michele.Sanges at otomelara.it>
> Date:
> Fri, 11 May 2007 16:37:14 +0200
> To:
> <gdal-dev at lists.maptools.org>
> To:
> Hello,
> is there a way to reproject a shape file of the entire world (eg. http://www.cipotato.org/diva/data/misc/world_adm0.zip) from geographic coordinates (lat/lon) to UTM, using the ogr2ogr utility?
> How do I manage the UTM zone?
> In order to avoid distorsion, is it possible to suddivide the original file in more lat/lon file, one for every UTM zone?
> Thanks a lot.
> Michele Sanges
