[Gdal-dev] speeding up the gdalwarp process for mosaicing and reprojection
John Mitchell mitchelljj98 at gmail.com
Mon May 14 17:51:56 EDT 2007
I have run the following gdalwarp command
gdalwarp.exe -wo SKIP_NOSOURCE=YES -rc -s_srs EPSG:" + EPSG + " -t_srs
EPSG:" + EPSG_wgs84 + " -of HFA " + " -q " + inputFiles + " " + outputFile
against a group of geotiff files which both mosaics and reprojects them to
wgs84 and it works fine, but it takes 22:47 hours to generate the 52.89 GB
mosaic.
Does anyone have any suggestions on how to speed up the gdalwarp process.  I
have noticed that the 4 processor server is only being utilized between
14-26% across all 4 processors.  Is their a way to force a higher
utilization of these processors?  I have in past tried to run 2 gdalwarp
jobs simultaneously and I have noticed that it takes them much longer
compared to the total time when running serially (meaning one after the
other).
Thanks,
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070514/2a0fa355/attachment.html
