[Gdal-dev] speeding up the gdalwarp process for mosaicing andreprojection
Ray Gardener rayg at daylongraphics.com
Mon May 14 20:19:34 EDT 2007
It looks like you should be able to (if you have a network) dupe the
input file to each machine, run a copy of gdalwarp on each machine with
custom -te params (-ts might vary on the last block), and then use
gdal_merge.py to assemble the results.
There's also gdalwarp's -multi option, which will use two threads
instead of one per gdalwarp instance.
Ray
