[Gdal-dev] SHP Files as Layers into a KML File
Mateusz Loskot mateusz at loskot.net
Tue May 15 08:59:29 EDT 2007
Philippe,
I think it should be easy to write Python script that will get a bunch
of KML files, each generated from a shapefile, and to some merging.
Unfortunately, I don't have any easier solution to suggest, for now.
Mat
Philippe de Franclieu wrote:
> Hello Mateusz,
> Thank you for your prompt reply.
> " if all shapes have the same schema". That's the point.
> The structures of the attribute data being different, merging shapes is not
> the solution. I should have imagine that earlier.
> No easy solution to superimpose heterogeneous shapes and data site by site
> I'm afraid.
> Best regards
> Philippe
>> -----Message d'origine-----
>> De : Mateusz Loskot [mailto:mateusz at loskot.net]
>> Envoyé : vendredi 11 mai 2007 21:32
>> À : Philippe de Franclieu
>> Cc : gdal-dev at lists.maptools.org
>> Objet : Re: [Gdal-dev] SHP Files as Layers into a KML File
>>> Hello,
>>> Objective : put several SHP files as different layers -
>>> different - into a KML file.
>>> Pb : I cannot -append -update the KML file : "Unable to
>> open existing output
>>> datasource 'out1.kml'".
>>> shp2kml.bat file is as follows :
>>> ogr2ogr -s_srs EPSG:27572 -t_srs EPSG:4326 -f "KML"
>> out1.kml in_1.shp -dsco
>>> NameField=LABEL -nln NewLayerName_1
>>> ogr2ogr -update -append -s_srs EPSG:27572 -t_srs EPSG:4326
>> -f "KML" out1.kml
>>> in_2.shp -dsco NameField=ID -nln NewLayerName_2
>> -f "KML" out1.kml
>>> in_3.shp -dsco NameField=ID -nln NewLayerName_3
>>> What is wrong?
>> Philippe,
>> As you can read in the KML driver doc
>> (http://www.gdal.org/ogr/drv_kml.html)
>> "OGR has limited support for KML writing and no support for
>> reading KML."
>> This is the reason of the error you're getting.
>> It may seems strange because you're trying to *write* KML but not to
>> read, but if you use -update option, this operation involves
>> datasource open and read steps.
>> So, it is not possible to generate single KML file in more
>> than one steps.
>> As workaround, you could merge shapefiles into single shapefile with
>> ogr2ogr, if all shapes have the same schema, and then build KML from
>> single shapefile.
>>> The other option, merge several SHP files into 'out.shp'
>> then convert it to
>>> 'out2.kml', does not work either.
>>> My shp2shp2kml.bat file is as follows :
>>> ogr2ogr -s_srs EPSG:27572 -t_srs EPSG:27572 -f "ESRI
>> Shapefile" out.shp
>>> in_1.shp -nln NewLayerName_1
>>> ogr2ogr -update -append -s_srs EPSG:27572 -t_srs EPSG:27572 -f "ESRI
>>> Shapefile" out.shp in_2.shp -nln NewLayerName_2
>>> Shapefile" out.shp in_3.shp -nln NewLayerName_3
>>> ogr2ogr -s_srs EPSG:27572 -t_srs EPSG:4326 -f "KML" out2.kml out.shp
>>> ERROR 1: Failed to create file out.shp\NewLayerName_2.shp.
>>> ERROR 4: Failed to open Shapefile 'out.shp\NewLayerName_2.shp'.
>>> ERROR 1: Terminating translation prematurely after failed
>> translation of
>>> layer in_2
>> OGR tries to resolve output datasource as a directory but not a file.
>> If you want to get new layer name (shapefile name), use directory
>> path as output datasource:
>> ogr2ogr -s_srs EPSG:27572 -t_srs EPSG:27572 -f "ESRI Shapefile" .
>> Here, in *current* directory (see the dot), you will get
>> NewLayerName_1.shp file, generated from in_1.shp.
>>> Also note that the -nln option does not replace the layer
>> name from 'out' to
>>> 'NewLayerName_%' whith the - f "ESRI Shapefile" option
>> while it does with
>>> the -f "KML".
>> Yes, because layer in ESRI Shapefile driver is...name of shapefile,
>> but if you use shapefile as a datasource, its filename works has two
>> meanings: datasoruce and layer name. It's not supported to
>> create, edit
>> and rename the same shapefile in single step.
>> If you run:
>> ogrinfo in_1.shp
>> you will get list of layers including *one* layer named in_1.
>> If you run:
>> ogrinfo /path/to/directory/but/not/to/shapefile
>> you will get list of N layers - names of shapefiles in given
>> directory.
>> Cheers
>> Mateusz Loskot
>> http://mateusz.loskot.net
Mateusz Loskot
