[Gdal-dev] remapping error for erdas imagine format within gdalwarp
John Mitchell mitchelljj98 at gmail.com
Wed May 16 09:21:18 EDT 2007
When running the following command:
gdalwarp.exe -srcnodata "0 0 0" -dstnodata "0 0 1" -rc -s_srs EPSG:26913
-t_srs EPSG:26913 -co tiled=yes -q -of hfa inputfile outputfile
I get the following error:
ERROR 6: SetNoDataValue() not supported for this dataset.
Which means that the remapping from "0 0 0" to "0 0 1" can't be performed.
When looking at the erdas imagine file after processing it appears to be
processed correctly except that the remapping does not occur.  This is not a
problem for geotiff files, but I can't use geotiffs for mosaics that are
over 4 gb in size.  Are their any alternatives?  Will I be able to mosaic
and remap to the big Tiff format when it comes out.
Thanks,
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070516/33d1e3c2/attachment.html
