[Gdal-dev] Writing 8-bit TIFFs using JPEG compression
Fri May 18 12:35:44 EDT 2007
Ray Gardener wrote:
> Has anyone been able to write 8-bit grayscale TIFFs using JPEG
> compression? I'm running into an issue where libtiff aborts because the
> photometric interpretation is invalid, even if min_is_black is used.
> Seems the JCS_GRAYSCALE flag never gets set by the driver. Using the
> JPEG driver itself is okay.
Ray,
I just tried it and it seemed to work, though I see the following
debug message, which I find suspicious:
GTiff: Setting JPEGCOLORMODE_RGB
Some of the jpeg stuff is very sensitive to the version of libtiff.  Are you
using the builtin libtiff?  The last public release?  libtiff-3.9 from CVS?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
