[Gdal-dev] Using GEOS in OGR C#
Jean Michel PIERRET jmp at geosys.com
Tue May 22 09:11:55 EDT 2007
I have the same problem with the latest gdal-svn-trunk-2007.05.21.
What are all the operations for enabled the GEOS support?
Thanks, Best Regards,
Jean-michel PIERRET - Poste  376
Tel : +33 (0)5 62 47 80 76
Mail : jmp at geosys.com
GEOSYS SA
-----Message d'origine-----
De : Tamas Szekeres [mailto:szekerest at gmail.com]
Envoyé : lundi 21 mai 2007 12:46
À : Jean Michel PIERRET
Cc : gdal-dev at lists.maptools.org
Objet : Re: [Gdal-dev] Using GEOS in OGR C#
It seems that the GEOS support is not actually enabled in your
project. In this case the Intersect method tests the overlapping of
the envelopes of the 2 geometries.
Are you sure the correct version of the dll-s have been loaded?
In the recent days I've changed the csharp bindings to link against
gdal14.dll instead of the static linking. The previous approach might
lead to various problems. Checkout the latest svn-trunk to rely on
these changes.
Best regards,
Tamas
2007/5/21, Jean Michel PIERRET <jmp at geosys.com>:
> Hi,
> I'm looking for someone who tries to use GEOS in the C# OGR.
> Thanks.
> Best Regards
> PIERRET Jean michel
> Hi,
> I try to use the OGR's library in Csharp and the GEOS support but I have 2
> problems. I'm using the "gdal-svn-trunk-2007.05.09".
> 1) With the objects "OSGEO.OGR.Geometry" when I use the method "Contains"
it
> turns over me an error "GEOS support not enabled". However I have
> uncommented the support GEOS in the file "nmake.opt" and the compilation
> return no error.
> GEOS_CFLAGS = -IE:\Mapserver\geos-2.2.3\source/capi -DHAVE_GEOS
> GEOS_LIB     = E:\Mapserver\geos-2.2.3\source/geos_c_i.lib
> When I use on the same object the method "Intersect" it seems work.
> 2) Can I use in csharp this method: "Ogr.CreateGeometryFromWkt".
> Best Regards
> PIERRET Jean michel
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
