[Gdal-dev] AAIGrid projection info
Tue May 22 12:05:38 EDT 2007
Sheykhet, Rostic wrote:
> Hi Frank/All,
> I am looking at a potential bug in ESRI SRS transform for AAIGrid, and
> just want to double check my assumptions.   Currently, for Projection
> TRANSVERSE in file ogr_srs_esri.cpp the projection parameter order is
> assumed as follows:
> PARAM_2 -> Latitude
> PARAM_3 -> Longitude
> PARAM_1 -> Scale
> PARAM_4 -> False Easting
> PARAM_5 -> False Northing
> In the file below, and several others like it, I see that PARAM_2 is
> actually Longitude and PARAM_3 is Latitude.
Rostic,
Your analysis is dead on.  I have filed this as a bug, and corrected it
in trunk and 1.4 branch as well as adding a test for this format.
   http://trac.osgeo.org/gdal/ticket/1649
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
