[Gdal-dev] Use of gdalwarp/translate utility
Matt Wilkie matt.wilkie at gov.yk.ca
Tue May 22 14:27:32 EDT 2007
> each projection. The GeoTIFF projections transform list is a great
> start, but still does not include the PROJ.4 syntax for each projection
> parameter. http://www.remotesensing.org/geotiff/proj_list/
Thanks Doug, that is a helpful resource. Refine the following at will if
it needs clarifying:
http://trac.osgeo.org/gdal/wiki/UserDocs/GdalTranslate#SyntaxforPROJ.4parameters
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
