[Gdal-dev] OGR2OGR GML coordinate reversal
Jesse Cleary jcleary at email.unc.edu
Tue May 22 16:24:56 EDT 2007
Hi folks
I'm trying to convert a GML file (3.1 I think) to a shapefile using
ogr2ogr (GDAL 1.3.2.0).  The conversion works and the attributes
translate nicely, but the destination file's point coordinates are
reversed from the source file.  The source GML file uses the following
nomenclature:
                <gml:Point>
                    <gml:pos>lat lon</gml:pos>
                </gml:Point>
OGR seems to expect the order to be lon then lat.  Is there any way to
tell ogr2ogr how to reverse the expected order of coordinates inside
these tags?  Or maybe my source file doesn't meet the GML spec and
should be changed to lon then lat?  Thanks...
Jesse
Jesse Cleary
Department of Marine Sciences
UNC Chapel Hill
334 Chapman Hall
(919) 962-4987
