[Gdal-dev] creating tiles from rasters using gdal
Paul Spencer pagameba at gmail.com
Tue May 22 21:18:29 EDT 2007
Thanks Frank.  One of the images that I tried was a tiff but I think
it must have been the PNGs that were poor.  When Assefa tried it by
converting to a tiled tiff first, performance was substantially better.
Cheers
Paul
On 15-May-07, at 1:53 PM, Frank Warmerdam wrote:
> Paul Spencer wrote:
>> I need to turn some rasters (png and tiff) into tiles for use in a
>> tiled map application.  For various reasons, these rasters are not
>> georeferenced and I don't need them to be.
>> This works perfectly but becomes increasingly slow - I'm
>> processing 6804 tiles out of a raster that is 21504 x 20736
>> pixels, the first 100 or so were fast but now it is down to 3-4
>> secs per tile (I'm at 4200 tiles so far).
>> How can I improve performance?  Is there an existing utility that
>> will do something like this or do I need to roll my own version of
>> gdal_translate?
> Paul,
> If the source raster is PNG then the problem is likely due to the file
> having to be decompressed from the beginning each time you process
> a tile.
> For the first row of tiles this isn't bad, but the further you go
> down the
> big file, the more of the png has to be decompressed on each run.
> If you can, just reprocess the big images into internally tiled
> TIFFs once
> before running the tiling script.
> Alternatively, you could accomplish the tiling using a script that
> keeps the
> input file open.  This would help because the in memory caching
> would prefer
> a lot of unnecessary re-decompressing.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://
> osgeo.org
|Paul Spencer                          pspencer at dmsolutions.ca    |
|Chief Technology Officer                                         |
|DM Solutions Group Inc                http://www.dmsolutions.ca/ |
