[Gdal-dev] Re: FW: gdal swig csharp wrapper problems
Tamas Szekeres szekerest at gmail.com
Thu May 24 17:01:24 EDT 2007
BTW, you can see the expected results of the various build steps on
various platforms at the GDAL buildbot:
http://buildbot.osgeo.org:8500/
Best regards,
Tamas
2007/5/24, Tamas Szekeres <szekerest at gmail.com>:
> Scott,
> Here are my suggestions to follow:
> 1. Since there were a high number of changes in the recent days I
> would suggest to use the current svn-trunk. Many of the changes were
> described at:
> http://trac.osgeo.org/gdal/wiki/GdalOgrCsharpVersions
> checkout the SVN trunk.
> 2. Download and extract the swigwin1.3.31 package
> 3. The following values should be set in nmake.opt (for the VC2005 builds)
> SWIG = [path to swig]\swig.exe
> MSVC_VER=1400
> 4 .You should compile the gdal core before compiling the csharp interface
> C:\GDAL> nmake /f makefile.vc
> 5. C#
> C:\GDAL\swig\csharp> nmake /f makefile.vc interface
> 6. Add the gdal root directory in the the PATH (alternatively you can
> copy gdal14.dll and proj.dll to the swig\csharp directory)
> set PATH=C:\GDAL;%PATH%
> 7.
> C:\GDAL\swig\csharp> nmake /f makefile.vc test
> If you don't have any of the required dll-s (like proj) download the
> recent FWTools package
> http://test.gdal.org/fwtools/FWTools130.exe
> Best regards,
> Tamas
> 2007/5/24, Scott Schulthess <scott at topozone.com>:
> > Hey, I'm having trouble following the directions on
> > http://trac.osgeo.org/gdal/wiki/GdalOgrCsharpCompile
> > This is the output I get I try to create the interface
> > Microsoft (R) Program Maintenance Utility Version 8.00.50727.42
> > Copyright (C) Microsoft Corporation.  All rights reserved.
> >         cd const
> >         C:\GDAL\swig\swig.exe -csharp -namespace GDAL -dllimport
> > gdal_gdalconst_
> > wrap -o gdalconst_wrap.c ../../include/gdalconst.i
> >         cd ..
> >         cd gdal
> >         C:\GDAL\swig\swig.exe -c++ -csharp -namespace GDAL  -dllimport
> > gdal_gdal
> > _wrap -I../../include/csharp -o gdal_wrap.cpp ../../include/gdal.i
> > ..\..\include\Band.i(215): Warning(453): Can't apply (IF_ERROR_RETURN_NONE).
> > No
> > typemaps are defined.
> >         cd ..
> >         cd osr
> >         C:\GDAL\swig\swig.exe -c++ -csharp -namespace OSR  -dllimport
> > gdal_osr_w
> > rap -I../../include/csharp -o osr_wrap.cpp ../../include/osr.i
> >         cd ..
> >         cd ogr
> >         C:\GDAL\swig\swig.exe -c++ -csharp -namespace OGR  -dllimport
> > gdal_osr_w
> > gdal_ogr_wr
> > ap -I../../include/csharp -o ogr_wrap.cpp ../../include/ogr.i
> >         cd ..
> > Notice the Band.I warning.
> > So then I ran nmake /f makefile.vc
> >         sn -k gdal.snk
> > Microsoft (R) .NET Framework Strong Name Utility  Version 2.0.50727.42
> > Copyright (c) Microsoft Corporation.  All rights reserved.
> > Key pair written to gdal.snk
> >         cd ogr
> >         nmake /nologo /f makefile.vc
> >         cl /nologo /MD /EHsc /Zi /D_CRT_SECURE_NO_DEPRECATE
> > /D_CRT_NONSTDC_NO_DE
> > PRECATE /Fd..\..\..\gdal.pdb -I..\..\..\port -I..\..\..\ogr -I..\..\..\gcore
> >  -I
> > ..\..\..\alg  /c ogr_wrap.cpp
> > ogr_wrap.cpp
> > C:\unzipped\gdal141\gdal-1.4.1\port\cpl_port.h(86) : fatal error C1083:
> > Cannot o
> > pen include file: 'cpl_config.h': No such file or directory
> > NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> > 8\VC\BIN\c
> > l.EXE"' : return code '0x2'
> > Stop.
> > 8\VC\BIN\n
> > make.EXE"' : return code '0x2'
> > Stop.
> > Well, within the prebuild library for windows
> > (http://trac.osgeo.org/gdal/wiki/BuildingOnWindows) I found
> > a cpl_config.h and moved it to /gdal/port
> > directory
> > Anyways now I get a bunch of the "unreachable expression code detected"
> > about 50 times and the "no gdal_i.lib"
> > osr\osr.cs(29,95): warning CS0429: Unreachable expression code detected
> > osr\osr.cs(35,95): warning CS0429: Unreachable expression code detected
> > osr\SpatialReference.cs(349,99): warning CS0429:
> >         detected
> >         link /dll /debug   ogr_wrap.obj      odbc32.lib odbccp32.lib
> > user32.lib
> >                            ..\..\gdal_i.lib /out:gdal_ogr_wrap.dll
> > Microsoft (R) Incremental Linker Version 8.00.50727.42
> > LINK : fatal error LNK1104: cannot open file '..\..\gdal_i.lib'
> > 8\VC\BIN\l
> > ink.EXE"' : return code '0x450'
> > Stop.
> > Well, there's a gdal_i.lib in those windows prebuild files I linked to
> > above, so I moved that into the gdal root directory.  No longer throws the
> > gdal_i.lib file not found error, but still throws the "unreachable
> > expression code detected' spam errors.
> > Now I run the test nmake /f makefile.vc test
> > and I get createdata.exe has an encountered a problem and needs to close.
> > Unhandled Exception: System.TypeInitializationException:
> > The type initializer fo
> > r 'OGR.ogr' threw an exception. --->
> > System.TypeInitializationException: The typ
> > e initializer for 'OGR.ogrPINVOKE' threw an exception. --->
> > ationException: The type initializer for 'SWIGExceptionHelper' threw an
> > exceptio
> > n. ---> System.DllNotFoundException: Unable to load DLL 'gdal_ogr_wrap': The
> > spe
> > cified module could not be found. (Exception from HRESULT: 0x8007007E)
> >    at
> > OGR.ogrPINVOKE.SWIGExceptionHelper.SWIGRegisterExceptionCallbacks_ogr(Exce
> > ptionDelegate applicationDelegate, ExceptionDelegate arithmeticDelegate,
> > Excepti
> > onDelegate divideByZeroDelegate, ExceptionDelegate indexOutOfRangeDelegate,
> > Exce
> > ptionDelegate invalidCastDelegate, ExceptionDelegate
> > invalidOperationDelegate, E
> > xceptionDelegate ioDelegate, ExceptionDelegate nullReferenceDelegate,
> > ExceptionD
> > elegate outOfMemoryDelegate, ExceptionDelegate overflowDelegate,
> > ExceptionDelega
> > te systemExceptionDelegate)
> >    at OGR.ogrPINVOKE.SWIGExceptionHelper..cctor() in
> > c:\unzipped\gdal141\gdal-1.
> > 4.1\swig\csharp\ogr\ogrPINVOKE.cs:line 106
> >    --- End of inner exception stack trace ---
> >    at OGR.ogrPINVOKE.SWIGExceptionHelper..ctor()
> >    at OGR.ogrPINVOKE..cctor() in
> > c:\unzipped\gdal141\gdal-1.4.1\swig\csharp\ogr\
> > ogrPINVOKE.cs:line 126
> >    at OGR.ogrPINVOKE.wkb25Bit_get()
> >    at OGR.ogr..cctor() in
> > c:\unzipped\gdal141\gdal-1.4.1\swig\csharp\ogr\ogr.cs:
> > line 102
> >    at OGR.ogr.RegisterAll()
> >    at CreateData.Main(String[] args)
> > NMAKE : fatal error U1077: '.\createdata.exe' : return code '0xe0434f4d'
> > Stop.
> > Please help.
> > Thanks!
> > -Scott
