[Gdal-dev] Transparent PNG with color table (palette)
Mon May 28 11:58:30 EDT 2007
Ludwig M Brinckmann wrote:
> Maybe this was a bit premature.
> Unfortunately, the MEM dataset does not support the SetGCPs method, even
> though the documentation says it 'should' .
> (" Memory datasets should support for most kinds of auxilary information
> including metadata, coordinate systems, georeferencing, GCPs, color
> interpretation, nodata, color tables and all pixel data types.")
Ludwig,
I see your analysis is correct - the MEM driver actually lacked GCP support
despite the docs.  I have added this in trunk, if that is convenient for you.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
