[Gdal-dev] Problem with AAIGrid's large integer
Wed May 30 16:28:40 EDT 2007
Matt Wilkie wrote:
> For the problem Etsushi encountered might it be sufficient to read the
> ./info/[gridname].sta file and set the default output type from there?
> (e.g. use the same approach esri does)
Matt,
The question is with regard to the ASCII Arc/Info Image Grid (AAIGRID)
format, not the AIGRID (ie. the binary format).  With the ascii grid
format it seems the only way I can find stuff out is to scan the whole
image which I am loath to do at open time.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
