No subject
Wed Nov 21 11:48:46 EST 2007
Synopsis
Boost.Build is a system for large project software construction built
on Boost.Jam, a descendant of "Perforce Jam", an open-source make
replacement[1]. Key features are:
    * A simple target description language
    * Build with your choice (or multiple) toolsets from a single
      command invocation
    * Build your choice of basic variants (e.g. debug, release,
      profile...) and subvariant modifications (e.g. inlining off)
      from a single command invocation
    * ``Feature Normalization'' allows target configurations to be
      described independently from the toolset used
    * Modular toolset description files allow build instructions for
      different toolsets to be described independently
    * Multiple subproject support
    * Automatic building of subproject dependencies
I hope this is helpful to some!
Cheers!
Mark
Mark Coletti | mailto:mcoletti at lychnobite.org | http://www.lychnobite.org/
		    Don't make me use uppercase...
------- =_aaaaaaaaaa0
Content-Type: application/x-tar; name="gdal.bjam.tgz"
Content-ID: <73237.1040237927.2 at lychnobite.org>
Content-Description: bjam files for GDAL
Content-Transfer-Encoding: base64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------- =_aaaaaaaaaa0--
