[Gdal-dev] status of ldshared build? (or, other options for OSX framework build)
Christopher Barker Chris.Barker at noaa.gov
Fri Nov 2 02:11:56 EDT 2007
Christopher Barker wrote:
> but is it as easy as just using without-python in
> .configure, then running setup.py after building and installing GDAL?
I just tried it (on Kubuntu Linux 7.10), and it appeared to build and
install OK, but I'm getting:
 >>> import osgeo.gdal
   File "<stdin>", line 1, in <module>
   File "osgeo/gdal.py", line 51, in <module>
     from gdalconst import *
   File "osgeo/gdalconst.py", line 123, in <module>
     GFT_Integer = _gdalconst.GFT_Integer
AttributeError: 'module' object has no attribute 'GFT_Integer'
(SVN head)
look familiar? I'm going to bed -- maybe I'll be able to poke into this
more tomorrow
Christopher Barker, Ph.D.
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
