[Gdal-dev] modis sinusoidal tiles: bug in gdal?
Vincent Schut schut at sarvision.nl
Tue Nov 6 05:35:27 EST 2007
[resending because message was too large to come through...]
Hi folks,
I'm starting to work with modis 500m data, which comes in hdf tiles in a
sinusoidal projection. It is their projection/crs which makes me wonder
whether I have actually paid enough attention in GIS class years ago...
I hope someone more knowledgeable regarding sinusoidal projections
and/or gdal's modis hdf support can help me with this.
Introduction:
this data comes in tiles of 2400x2400 pixels, which seem to be just cut
from a sinusoidal world map grid (see
http://nsidc.org/data/modis/landgrid.html for an image of the grid). The
grid is 36 tiles wide (lon) by 18 tiles high (lat).
I have always presumed that the idea of a projection/crs (well, in
raster imagery, that is) is to have a linear grid spacing horizontally
and vertically (though hor and vert need not be the same) for the whole
range where the crs is valid. That means, pixel size for the entire area
is constant. For SIN, I'd think that would be the whole world, so pixel
sizes for any tile should be equal with any other tile. That way, and
only that way, they would match as in the world wide grid as shown on
the picture mentioned above.
The puzzle:
Then I tried to merge some modis tiles by using VRT, using vrt_merge.py.
I was very puzzeled when I got an error message telling me it wouldn't
merge my tiles because they did not have the same scale. After some
investigation, it indeed appeared they didn't! Pixel size (as calculated
by gdal) is different per tile. At around (0,0) degrees latlong, pixels
are square and of size 463.312716527916677 meters. The further one goes
from the equator or 0 deg longitude, the more the pixel size in that
direction differs from this 463.312716527916677 and pixels are not
square anymore.
I am lost here. Is gdal doing something wrong, are modis' sin tiles not
really sin grid tiles, or have I always underestimated projection/crs
limits and their usefulness for raster grids?
For now, I assume gdal is wrong :-) I'd like to test, but don't know
how. I can make some tiles publicly available on an ftp site if
necessary, and I'll post the gdalinfo for a couple of them (actually a
couple of the subdatasets of the tile hdf files) in this mail, first
without metadata (there is quite some), then with metadata, because I
assume gdal is calculating ul/lr from the hdf metadata. Could it be that
gdal is not taking into account the custom sphere modis uses?
Regards,
Vincent
the gdalinfo's:
tile h18 v09 (ul = 0,0, note the square pixels)
Driver: HDF4Image/HDF4 Dataset
Files: MCD43A4.A2007233.h18v09.005.2007257192957.hdf
Size is 2400, 2400
Coordinate System is:
PROJCS["unnamed",
    GEOGCS["Unknown datum based upon the custom spheroid",
        DATUM["Not specified (based on custom spheroid)",
            SPHEROID["Custom spheroid",6371007.181,0]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Sinusoidal"],
    PARAMETER["longitude_of_center",0],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    UNIT["Meter",1]]
Origin = (0.000000000000000,-0.000000000000000)
Pixel Size = (463.312716527916677,-463.312716527916677)
Corner Coordinates:
Upper Left  (   0.0000000,   0.0000000) (  0d 0'0.01"E,  0d 0'0.01"N)
Lower Left  (       0.000,-1111950.520) (  0d 0'0.01"E, 10d 0'0.00"S)
Upper Right ( 1111950.520,       0.000) ( 10d 0'0.00"E,  0d 0'0.01"N)
Lower Right ( 1111950.520,-1111950.520) ( 10d 9'15.36"E, 10d 0'0.00"S)
Center      (  555975.260, -555975.260) (  5d 1'8.76"E,  5d 0'0.00"S)
Band 1 Block=2400x1 Type=Int16, ColorInterp=Gray
  NoData Value=32767
tile: h17 v01
Files: MCD43A4.A2007233.h17v01.005.2007258182118.hdf
Size is 2400, 2400
PROJCS["unnamed",
    UNIT["Meter",1]]
Origin = (-1111950.519667000044137,8895604.157332999631763)
Pixel Size = (463.312716527916677,-463.312716527499731)
Corner Coordinates:
Upper Left  (-1111950.520, 8895604.157) ( 57d35'15.74"W, 80d 0'0.00"N)
Lower Left  (-1111950.520, 7783653.638) ( 29d14'16.96"W, 70d 0'0.00"N)
Upper Right (       0.000, 8895604.157) (  0d 0'0.01"E, 80d 0'0.00"N)
Lower Right (       0.000, 7783653.638) (  0d 0'0.01"E, 70d 0'0.00"N)
Center      ( -555975.260, 8339628.897) ( 19d19'6.66"W, 75d 0'0.00"N)
  NoData Value=32767
tile h08 v06
Files: MCD43A4.A2007233.h08v06.005.2007258024555.hdf
Size is 2400, 2400
PROJCS["unnamed",
    UNIT["Meter",1]]
Origin = (-11119505.196667000651360,3335851.558999999891967)
Pixel Size = (463.312716527917246,-463.312716527916677)
Corner Coordinates:
Upper Left  (-11119505.197, 3335851.559) (115d28'12.19"W, 30d 0'0.00"N)
Lower Left  (-11119505.197, 2223901.039) (106d25'4.00"W, 20d 0'0.00"N)
Upper Right (-10007554.677, 3335851.559) (103d55'22.97"W, 30d 0'0.00"N)
Lower Right (-10007554.677, 2223901.039) ( 95d46'33.60"W, 20d 0'0.00"N)
Center      (-10563529.937, 2779876.299) (104d49'15.25"W, 25d 0'0.00"N)
  NoData Value=32767
the same tiles gdalinfo including metadata:
tile h18 v08 (ul = 0,0)
Size is 2400, 2400
PROJCS["unnamed",
    UNIT["Meter",1]]
Metadata:
  HDFEOSVersion=HDFEOS_V2.9
  LOCALGRANULEID=MCD43A4.A2007233.h18v09.005.2007257192957.hdf
  PRODUCTIONDATETIME=2007-09-14T19:29:57.000Z
  DAYNIGHTFLAG=Day
  REPROCESSINGACTUAL=reprocessed
  LOCALVERSIONID=5.0.6
  REPROCESSINGPLANNED=further update is anticipated
  SCIENCEQUALITYFLAG=Not Investigated
  AUTOMATICQUALITYFLAGEXPLANATION=Passed was set as a default value.
More algorithm will be developed
  AUTOMATICQUALITYFLAG=Passed
  SCIENCEQUALITYFLAGEXPLANATION=See
http://landweb.nascom/nasa.gov/cgi-bin/QA_WWW/qaFlagPage.cgi?sat=aqua
the product Science Quality status.
  PARAMETERNAME=Nadir_Reflectance
  VERSIONID=5
  SHORTNAME=MCD43A4
  INPUTPOINTER=MYD09GHK.A2007233.h18v09.005.2007236053746.hdf,
MYD09GST.A2007233.h18v09.005.2007236053311.hdf,
MYDMGGAD.A2007233.h18v09.005.2007236053220.hdf,
MYDPTHKM.A2007233.h18v09.005.2007236053206.hdf,
MYD09GHK.A2007234.h18v09.005.2007237120850.hdf,
MYD09GST.A2007234.h18v09.005.2007237120515.hdf,
MYDMGGAD.A2007234.h18v09.005.2007237120428.hdf,
MYDPTHKM.A2007234.h18v09.005.2007237120423.hdf,
MYD09GHK.A2007235.h18v09.005.2007238114938.hdf,
MYD09GST.A2007235.h18v09.005.2007238114729.hdf,
MYDMGGAD.A2007235.h18v09.005.2007238114707.hdf,
MYDPTHKM.A2007235.h18v09.005.2007238114702.hdf,
MYD09GHK.A2007236.h18v09.005.2007239105155.hdf,
MYD09GST.A2007236.h18v09.005.2007239103755.hdf,
MYDMGGAD.A2007236.h18v09.005.2007239103643.hdf,
MYDPTHKM.A2007236.h18v09.005.2007239103614.hdf,
MYD09GHK.A2007237.h18v09.005.2007241063343.hdf,
MYD09GST.A2007237.h18v09.005.2007241061301.hdf,
MYDMGGAD.A2007237.h18v09.005.2007241061129.hdf,
MYDPTHKM.A2007237.h18v09.005.2007241061049.hdf,
MYD09GHK.A2007238.h18v09.005.2007241214859.hdf,
MYD09GST.A2007238.h18v09.005.2007241212740.hdf,
MYDMGGAD.A2007238.h18v09.005.2007241212617.hdf,
MYDPTHKM.A2007238.h18v09.005.2007241212558.hdf,
MYD09GHK.A2007239.h18v09.005.2007242054538.hdf,
MYD09GST.A2007239.h18v09.005.2007242053456.hdf,
MYDMGGAD.A2007239.h18v09.005.2007242053352.hdf,
MYDPTHKM.A2007239.h18v09.005.2007242053333.hdf,
MYD09GHK.A2007240.h18v09.005.2007243154617.hdf,
MYD09GST.A2007240.h18v09.005.2007243154026.hdf,
MYDMGGAD.A2007240.h18v09.005.2007243153840.hdf,
MYDPTHKM.A2007240.h18v09.005.2007243153819.hdf,
MYD09GHK.A2007241.h18v09.005.2007244030904.hdf,
MYD09GST.A2007241.h18v09.005.2007244023636.hdf,
MYDMGGAD.A2007241.h18v09.005.2007244023450.hdf,
MYDPTHKM.A2007241.h18v09.005.2007244023400.hdf,
MYD09GHK.A2007242.h18v09.005.2007245042617.hdf,
MYD09GST.A2007242.h18v09.005.2007245040916.hdf,
MYDMGGAD.A2007242.h18v09.005.2007245040636.hdf,
MYDPTHKM.A2007242.h18v09.005.2007245040534.hdf,
MYD09GHK.A2007243.h18v09.005.2007248130715.hdf,
MYD09GST.A2007243.h18v09.005.2007248130346.hdf,
MYDMGGAD.A2007243.h18v09.005.2007248130208.hdf,
MYDPTHKM.A2007243.h18v09.005.2007248130203.hdf,
MYD09GHK.A2007244.h18v09.005.2007247083702.hdf,
MYD09GST.A2007244.h18v09.005.2007247082252.hdf,
MYDMGGAD.A2007244.h18v09.005.2007247082143.hdf,
MYDPTHKM.A2007244.h18v09.005.2007247082108.hdf,
MYD09GHK.A2007245.h18v09.005.2007248005936.hdf,
MYD09GST.A2007245.h18v09.005.2007248004329.hdf,
MYDMGGAD.A2007245.h18v09.005.2007248004128.hdf,
MYDPTHKM.A2007245.h18v09.005.2007248004036.hdf,
MYD09GHK.A2007246.h18v09.005.2007255073637.hdf,
MYD09GST.A2007246.h18v09.005.2007255072421.hdf,
MYDMGGAD.A2007246.h18v09.005.2007255072312.hdf,
MYDPTHKM.A2007246.h18v09.005.2007255072247.hdf,
MYD09GHK.A2007247.h18v09.005.2007255144553.hdf,
MYD09GST.A2007247.h18v09.005.2007255143217.hdf,
MYDMGGAD.A2007247.h18v09.005.2007255143018.hdf,
MYDPTHKM.A2007247.h18v09.005.2007255142929.hdf,
MYD09GHK.A2007248.h18v09.005.2007251070617.hdf,
MYD09GST.A2007248.h18v09.005.2007251065138.hdf,
MYDMGGAD.A2007248.h18v09.005.2007251065039.hdf,
MYDPTHKM.A2007248.h18v09.005.2007251065012.hdf,
MOD09GHK.A2007233.h18v09.005.2007235214503.hdf,
MOD09GST.A2007233.h18v09.005.2007235214044.hdf,
MODMGGAD.A2007233.h18v09.005.2007235213836.hdf,
MODPTHKM.A2007233.h18v09.005.2007235213820.hdf,
MOD09GHK.A2007234.h18v09.005.2007237145653.hdf,
MOD09GST.A2007234.h18v09.005.2007237145417.hdf,
MODMGGAD.A2007234.h18v09.005.2007237145334.hdf,
MODPTHKM.A2007234.h18v09.005.2007237145329.hdf,
MOD09GHK.A2007235.h18v09.005.2007238021348.hdf,
MOD09GST.A2007235.h18v09.005.2007238021112.hdf,
MODMGGAD.A2007235.h18v09.005.2007238021044.hdf,
MODPTHKM.A2007235.h18v09.005.2007238021038.hdf,
MOD09GHK.A2007236.h18v09.005.2007239091305.hdf,
MOD09GST.A2007236.h18v09.005.2007239085423.hdf,
MODMGGAD.A2007236.h18v09.005.2007239085153.hdf,
MODPTHKM.A2007236.h18v09.005.2007239085045.hdf,
MOD09GHK.A2007237.h18v09.005.2007241014843.hdf,
MOD09GST.A2007237.h18v09.005.2007241013326.hdf,
MODMGGAD.A2007237.h18v09.005.2007241012505.hdf,
MODPTHKM.A2007237.h18v09.005.2007241012429.hdf,
MOD09GHK.A2007238.h18v09.005.2007241215222.hdf,
MOD09GST.A2007238.h18v09.005.2007241213217.hdf,
MODMGGAD.A2007238.h18v09.005.2007241213026.hdf,
MODPTHKM.A2007238.h18v09.005.2007241212953.hdf,
MOD09GHK.A2007239.h18v09.005.2007242072457.hdf,
MOD09GST.A2007239.h18v09.005.2007242071604.hdf,
MODMGGAD.A2007239.h18v09.005.2007242071420.hdf,
MODPTHKM.A2007239.h18v09.005.2007242071346.hdf,
MOD09GHK.A2007240.h18v09.005.2007243004029.hdf,
MOD09GST.A2007240.h18v09.005.2007243003106.hdf,
MODMGGAD.A2007240.h18v09.005.2007243002958.hdf,
MODPTHKM.A2007240.h18v09.005.2007243002925.hdf,
MOD09GHK.A2007241.h18v09.005.2007243231354.hdf,
MOD09GST.A2007241.h18v09.005.2007243225712.hdf,
MODMGGAD.A2007241.h18v09.005.2007243225614.hdf,
MODPTHKM.A2007241.h18v09.005.2007243225549.hdf,
MOD09GHK.A2007242.h18v09.005.2007245004458.hdf,
MOD09GST.A2007242.h18v09.005.2007245003432.hdf,
MODMGGAD.A2007242.h18v09.005.2007245003334.hdf,
MODPTHKM.A2007242.h18v09.005.2007245003303.hdf,
MOD09GHK.A2007243.h18v09.005.2007246012406.hdf,
MOD09GST.A2007243.h18v09.005.2007246011856.hdf,
MODMGGAD.A2007243.h18v09.005.2007246011821.hdf,
MODPTHKM.A2007243.h18v09.005.2007246011809.hdf,
MOD09GHK.A2007244.h18v09.005.2007246225108.hdf,
MOD09GST.A2007244.h18v09.005.2007246224524.hdf,
MODMGGAD.A2007244.h18v09.005.2007246224437.hdf,
MODPTHKM.A2007244.h18v09.005.2007246224414.hdf,
MOD09GHK.A2007245.h18v09.005.2007248075944.hdf,
MOD09GST.A2007245.h18v09.005.2007248074731.hdf,
MODMGGAD.A2007245.h18v09.005.2007248074647.hdf,
MODPTHKM.A2007245.h18v09.005.2007248074628.hdf,
MOD09GHK.A2007246.h18v09.005.2007249082516.hdf,
MOD09GST.A2007246.h18v09.005.2007249081943.hdf,
MODMGGAD.A2007246.h18v09.005.2007249081846.hdf,
MODPTHKM.A2007246.h18v09.005.2007249081826.hdf,
MOD09GHK.A2007247.h18v09.005.2007249234457.hdf,
MOD09GST.A2007247.h18v09.005.2007249234128.hdf,
MODMGGAD.A2007247.h18v09.005.2007249234101.hdf,
MODPTHKM.A2007247.h18v09.005.2007249234055.hdf,
MOD09GHK.A2007248.h18v09.005.2007250201505.hdf,
MOD09GST.A2007248.h18v09.005.2007250201055.hdf,
MODMGGAD.A2007248.h18v09.005.2007250200944.hdf,
MODPTHKM.A2007248.h18v09.005.2007250200934.hdf,
BRDF_DB.A2001001.h18v09.002.2005235120000.hdf
  GRINGPOINTLONGITUDE=-0.000495318715299631, -2.76300131940985e-15,
10.0088830882149, 10.1623357757029
  GRINGPOINTLATITUDE=-10.0006497593949, -2.21691396828058e-15,
0.000515336202014404, -9.99987677086012
  GRINGPOINTSEQUENCENO=1, 2, 3, 4
  EXCLUSIONGRINGFLAG=N
  RANGEENDINGDATE=2007-09-05
  RANGEENDINGTIME=23:59:59.999999
  RANGEBEGINNINGDATE=2007-08-21
  RANGEBEGINNINGTIME=00:00:00.000000
  PGEVERSION=5.0.11
  ASSOCIATEDSENSORSHORTNAME=MODIS
  ASSOCIATEDPLATFORMSHORTNAME=Terra
  ASSOCIATEDINSTRUMENTSHORTNAME=MODIS
  ASSOCIATEDPLATFORMSHORTNAME=Aqua
  QAPERCENTGOODQUALITY=0
  QAPERCENTOTHERQUALITY=0
  QAPERCENTNOTPRODUCEDCLOUD=0
  QAPERCENTNOTPRODUCEDOTHER=100
  HORIZONTALTILENUMBER=18
  VERTICALTILENUMBER=09
  TileID=51018009
  BRDFCODEID=AMBRALS_V4.0R1
  SETUPFILEID=6121997
  ALBEDOFILEID=6121997
  BRDFDATABASEVERSION=v1.0500m
  PERCENTLANDINTILE=40.423603
  PERCENTPROCESSEDINTILE=12.187835
  PERCENTNEWBRDFS=0.022246
  PERCENTSHAPEFIXEDBRDFS=12.165589
  PERCENTSUBSTITUTEBRDFS=0.000000
  AVERAGENUMBEROBS=0.096625
  WESTBOUNDINGCOORDINATE=4.25322203204892e-15
  NORTHBOUNDINGCOORDINATE=-2.12661101602446e-15
  EASTBOUNDINGCOORDINATE=10.1627280063491
  SOUTHBOUNDINGCOORDINATE=-9.99999999910197
  GEOANYABNORMAL=False
  GEOESTMAXRMSERROR=75.0
  LONGNAME=MODIS/Terra+Aqua Nadir BRDF-Adjusted Reflectance 16-Day L3
Global 500m SIN Grid
  SPSOPARAMETERS=none, derived from 3669
  PROCESSINGCENTER=MODAPS
  CHARACTERISTICBINANGULARSIZE=15.0
  CHARACTERISTICBINSIZE=463.312716527778
  DATACOLUMNS=2400
  DATAROWS=2400
  GLOBALGRIDCOLUMNS=86400
  GLOBALGRIDROWS=43200
  MAXIMUMOBSERVATIONS=4
  NUMBEROFGRANULES=0
  COVERAGECALCULATIONMETHOD=volume
  NADIRDATARESOLUTION=500m
  PROCESSINGENVIRONMENT=Linux minion5124 2.6.8.1-26mdksmp #1 SMP Mon Nov
28 12:40:04 MST 2005 i686 IntelR PentiumR III CPU family      1133MHz
unknown GNU/Linux
  DESCRREVISION=5.1
  long_name=Nadir_Reflectance_Band1
  units=reflectance, no units
  valid_range=0, 32766
  _FillValue=32767
  scale_factor=0.0001
  add_offset=0
  scale_factor_err=0
  add_offset_err=0
  calibrated_nt=5
Corner Coordinates:
  NoData Value=32767
tile: h17 v01
Size is 2400, 2400
PROJCS["unnamed",
    UNIT["Meter",1]]
Metadata:
  LOCALGRANULEID=MCD43A4.A2007233.h17v01.005.2007258182118.hdf
  PRODUCTIONDATETIME=2007-09-15T18:21:18.000Z
  DAYNIGHTFLAG=Both
  VERSIONID=5
  SHORTNAME=MCD43A4
  INPUTPOINTER=MYD09GHK.A2007233.h17v01.005.2007236222856.hdf,
MYD09GST.A2007233.h17v01.005.2007236201630.hdf,
MYDMGGAD.A2007233.h17v01.005.2007236063600.hdf,
MYDPTHKM.A2007233.h17v01.005.2007236063258.hdf,
MYD09GHK.A2007234.h17v01.005.2007237111611.hdf,
MYD09GST.A2007234.h17v01.005.2007237103936.hdf,
MYDMGGAD.A2007234.h17v01.005.2007237103511.hdf,
MYDPTHKM.A2007234.h17v01.005.2007237103353.hdf,
MYD09GHK.A2007235.h17v01.005.2007238134639.hdf,
MYD09GST.A2007235.h17v01.005.2007238122331.hdf,
MYDMGGAD.A2007235.h17v01.005.2007238121637.hdf,
MYDPTHKM.A2007235.h17v01.005.2007238121158.hdf,
MYD09GHK.A2007236.h17v01.005.2007239122711.hdf,
MYD09GST.A2007236.h17v01.005.2007239112111.hdf,
MYDMGGAD.A2007236.h17v01.005.2007239111159.hdf,
MYDPTHKM.A2007236.h17v01.005.2007239110816.hdf,
MYD09GHK.A2007237.h17v01.005.2007241063713.hdf,
MYD09GST.A2007237.h17v01.005.2007241035122.hdf,
MYDMGGAD.A2007237.h17v01.005.2007241030744.hdf,
MYDPTHKM.A2007237.h17v01.005.2007241030435.hdf,
MYD09GHK.A2007238.h17v01.005.2007242000942.hdf,
MYD09GST.A2007238.h17v01.005.2007241212456.hdf,
MYDMGGAD.A2007238.h17v01.005.2007241204045.hdf,
MYDPTHKM.A2007238.h17v01.005.2007241202927.hdf,
MYD09GHK.A2007239.h17v01.005.2007242081058.hdf,
MYD09GST.A2007239.h17v01.005.2007242065819.hdf,
MYDMGGAD.A2007239.h17v01.005.2007242064753.hdf,
MYDPTHKM.A2007239.h17v01.005.2007242064433.hdf,
MYD09GHK.A2007240.h17v01.005.2007243192640.hdf,
MYD09GST.A2007240.h17v01.005.2007243162910.hdf,
MYDMGGAD.A2007240.h17v01.005.2007243161843.hdf,
MYDPTHKM.A2007240.h17v01.005.2007243161258.hdf,
MYD09GHK.A2007241.h17v01.005.2007244062704.hdf,
MYD09GST.A2007241.h17v01.005.2007244030438.hdf,
MYDMGGAD.A2007241.h17v01.005.2007244023659.hdf,
MYDPTHKM.A2007241.h17v01.005.2007244022907.hdf,
MYD09GHK.A2007242.h17v01.005.2007245110353.hdf,
MYD09GST.A2007242.h17v01.005.2007245093532.hdf,
MYDMGGAD.A2007242.h17v01.005.2007245090954.hdf,
MYDPTHKM.A2007242.h17v01.005.2007245085748.hdf,
MYD09GHK.A2007243.h17v01.005.2007248134615.hdf,
MYD09GST.A2007243.h17v01.005.2007248120549.hdf,
MYDMGGAD.A2007243.h17v01.005.2007248115402.hdf,
MYDPTHKM.A2007243.h17v01.005.2007248115049.hdf,
MYD09GHK.A2007244.h17v01.005.2007247074620.hdf,
MYD09GST.A2007244.h17v01.005.2007247063447.hdf,
MYDMGGAD.A2007244.h17v01.005.2007247062929.hdf,
MYDPTHKM.A2007244.h17v01.005.2007247062748.hdf,
MYD09GHK.A2007245.h17v01.005.2007248023226.hdf,
MYD09GST.A2007245.h17v01.005.2007248003758.hdf,
MYDMGGAD.A2007245.h17v01.005.2007248002740.hdf,
MYDPTHKM.A2007245.h17v01.005.2007248002157.hdf,
MYD09GHK.A2007246.h17v01.005.2007255075611.hdf,
MYD09GST.A2007246.h17v01.005.2007255062815.hdf,
MYDMGGAD.A2007246.h17v01.005.2007255061737.hdf,
MYDPTHKM.A2007246.h17v01.005.2007255061323.hdf,
MYD09GHK.A2007247.h17v01.005.2007255162151.hdf,
MYD09GST.A2007247.h17v01.005.2007255130850.hdf,
MYDMGGAD.A2007247.h17v01.005.2007255121258.hdf,
MYDPTHKM.A2007247.h17v01.005.2007255121053.hdf,
MYD09GHK.A2007248.h17v01.005.2007251092025.hdf,
MYD09GST.A2007248.h17v01.005.2007251071817.hdf,
MYDMGGAD.A2007248.h17v01.005.2007251070759.hdf,
MYDPTHKM.A2007248.h17v01.005.2007251070306.hdf,
MOD09GHK.A2007233.h17v01.005.2007235231318.hdf,
MOD09GST.A2007233.h17v01.005.2007235202757.hdf,
MODMGGAD.A2007233.h17v01.005.2007235195859.hdf,
MODPTHKM.A2007233.h17v01.005.2007235195245.hdf,
MOD09GHK.A2007234.h17v01.005.2007237135611.hdf,
MOD09GST.A2007234.h17v01.005.2007237131100.hdf,
MODMGGAD.A2007234.h17v01.005.2007237130257.hdf,
MODPTHKM.A2007234.h17v01.005.2007237130131.hdf,
MOD09GHK.A2007235.h17v01.005.2007238014117.hdf,
MOD09GST.A2007235.h17v01.005.2007238010732.hdf,
MODMGGAD.A2007235.h17v01.005.2007238010341.hdf,
MODPTHKM.A2007235.h17v01.005.2007238010239.hdf,
MOD09GHK.A2007236.h17v01.005.2007239071327.hdf,
MOD09GST.A2007236.h17v01.005.2007239063205.hdf,
MODMGGAD.A2007236.h17v01.005.2007239062729.hdf,
MODPTHKM.A2007236.h17v01.005.2007239062633.hdf,
MOD09GHK.A2007237.h17v01.005.2007241035814.hdf,
MOD09GST.A2007237.h17v01.005.2007241023721.hdf,
MODMGGAD.A2007237.h17v01.005.2007241021501.hdf,
MODPTHKM.A2007237.h17v01.005.2007241021036.hdf,
MOD09GHK.A2007238.h17v01.005.2007241181850.hdf,
MOD09GST.A2007238.h17v01.005.2007241165042.hdf,
MODMGGAD.A2007238.h17v01.005.2007241164133.hdf,
MODPTHKM.A2007238.h17v01.005.2007241163813.hdf,
MOD09GHK.A2007239.h17v01.005.2007242064203.hdf,
MOD09GST.A2007239.h17v01.005.2007242050934.hdf,
MODMGGAD.A2007239.h17v01.005.2007242044745.hdf,
MODPTHKM.A2007239.h17v01.005.2007242044316.hdf,
MOD09GHK.A2007240.h17v01.005.2007243002350.hdf,
MOD09GST.A2007240.h17v01.005.2007242220512.hdf,
MODMGGAD.A2007240.h17v01.005.2007242213145.hdf,
MODPTHKM.A2007240.h17v01.005.2007242212325.hdf,
MOD09GHK.A2007241.h17v01.005.2007244020115.hdf,
MOD09GST.A2007241.h17v01.005.2007243220830.hdf,
MODMGGAD.A2007241.h17v01.005.2007243212356.hdf,
MODPTHKM.A2007241.h17v01.005.2007243211229.hdf,
MOD09GHK.A2007242.h17v01.005.2007245010303.hdf,
MOD09GST.A2007242.h17v01.005.2007244235553.hdf,
MODMGGAD.A2007242.h17v01.005.2007244235044.hdf,
MODPTHKM.A2007242.h17v01.005.2007244234831.hdf,
MOD09GHK.A2007243.h17v01.005.2007246042209.hdf,
MOD09GST.A2007243.h17v01.005.2007246030516.hdf,
MODMGGAD.A2007243.h17v01.005.2007246024337.hdf,
MODPTHKM.A2007243.h17v01.005.2007246023927.hdf,
MOD09GHK.A2007244.h17v01.005.2007246235842.hdf,
MOD09GST.A2007244.h17v01.005.2007246220840.hdf,
MODMGGAD.A2007244.h17v01.005.2007246220100.hdf,
MODPTHKM.A2007244.h17v01.005.2007246215655.hdf,
MOD09GHK.A2007245.h17v01.005.2007248072411.hdf,
MOD09GST.A2007245.h17v01.005.2007248062224.hdf,
MODMGGAD.A2007245.h17v01.005.2007248052154.hdf,
MODPTHKM.A2007245.h17v01.005.2007248052020.hdf,
MOD09GHK.A2007246.h17v01.005.2007249073419.hdf,
MOD09GST.A2007246.h17v01.005.2007249062338.hdf,
MODMGGAD.A2007246.h17v01.005.2007249061018.hdf,
MODPTHKM.A2007246.h17v01.005.2007249060849.hdf,
MOD09GHK.A2007247.h17v01.005.2007250002634.hdf,
MOD09GST.A2007247.h17v01.005.2007249231010.hdf,
MODMGGAD.A2007247.h17v01.005.2007249230119.hdf,
MODPTHKM.A2007247.h17v01.005.2007249225736.hdf,
MOD09GHK.A2007248.h17v01.005.2007250210138.hdf,
MOD09GST.A2007248.h17v01.005.2007250174801.hdf,
MODMGGAD.A2007248.h17v01.005.2007250172712.hdf,
MODPTHKM.A2007248.h17v01.005.2007250172416.hdf,
BRDF_DB.A2001001.h17v01.002.2005235120000.hdf
  GRINGPOINTLONGITUDE=-29.1844410463807, -58.6470557489562,
0.164444841055828, 0.0201431634776088
  GRINGPOINTLATITUDE=69.3805018417384, 79.8967917713976,
80.0268628815066, 69.3949614027661
  PGEVERSION=5.0.11
  QAPERCENTGOODQUALITY=18
  QAPERCENTOTHERQUALITY=28
  QAPERCENTNOTPRODUCEDOTHER=54
  HORIZONTALTILENUMBER=17
  VERTICALTILENUMBER=01
  TileID=51017001
  SETUPFILEID=6121997
  PERCENTLANDINTILE=87.166880
  PERCENTPROCESSEDINTILE=93.238151
  PERCENTNEWBRDFS=56.176027
  PERCENTSHAPEFIXEDBRDFS=37.062124
  AVERAGENUMBEROBS=6.685058
  WESTBOUNDINGCOORDINATE=-57.5877047853133
  NORTHBOUNDINGCOORDINATE=79.9999999928158
  EASTBOUNDINGCOORDINATE=0.0479897539877856
  SOUTHBOUNDINGCOORDINATE=69.9999999937138
  DATACOLUMNS=2400
  DATAROWS=2400
  MAXIMUMOBSERVATIONS=19
  NUMBEROFGRANULES=0
  PROCESSINGENVIRONMENT=Linux minion5244 2.6.20.3 #1 SMP Thu Mar 22
09:36:24 EST 2007 i686 IntelR XeonR CPU            5140  @ 2.33GHz
unknown GNU/Linux
  DESCRREVISION=5.1
  _FillValue=32767
  scale_factor=0.0001
  add_offset=0
  scale_factor_err=0
  add_offset_err=0
  calibrated_nt=5
Corner Coordinates:
  NoData Value=32767
tile h08 v06
Size is 2400, 2400
PROJCS["unnamed",
    UNIT["Meter",1]]
Metadata:
  LOCALGRANULEID=MCD43A4.A2007233.h08v06.005.2007258024555.hdf
  PRODUCTIONDATETIME=2007-09-15T02:45:55.000Z
  DAYNIGHTFLAG=Day
  VERSIONID=5
  SHORTNAME=MCD43A4
  INPUTPOINTER=MYD09GHK.A2007233.h08v06.005.2007236055001.hdf,
MYD09GST.A2007233.h08v06.005.2007236054524.hdf,
MYDMGGAD.A2007233.h08v06.005.2007236054418.hdf,
MYDPTHKM.A2007233.h08v06.005.2007236054406.hdf,
MYD09GHK.A2007234.h08v06.005.2007237125257.hdf,
MYD09GST.A2007234.h08v06.005.2007237123958.hdf,
MYDMGGAD.A2007234.h08v06.005.2007237123812.hdf,
MYDPTHKM.A2007234.h08v06.005.2007237123731.hdf,
MYD09GHK.A2007235.h08v06.005.2007238122041.hdf,
MYD09GST.A2007235.h08v06.005.2007238120909.hdf,
MYDMGGAD.A2007235.h08v06.005.2007238120819.hdf,
MYDPTHKM.A2007235.h08v06.005.2007238120804.hdf,
MYD09GHK.A2007236.h08v06.005.2007239105629.hdf,
MYD09GST.A2007236.h08v06.005.2007239104810.hdf,
MYDMGGAD.A2007236.h08v06.005.2007239104711.hdf,
MYDPTHKM.A2007236.h08v06.005.2007239104649.hdf,
MYD09GHK.A2007237.h08v06.005.2007241070752.hdf,
MYD09GST.A2007237.h08v06.005.2007241065104.hdf,
MYDMGGAD.A2007237.h08v06.005.2007241064907.hdf,
MYDPTHKM.A2007237.h08v06.005.2007241064828.hdf,
MYD09GHK.A2007238.h08v06.005.2007241221949.hdf,
MYD09GST.A2007238.h08v06.005.2007241220654.hdf,
MYDMGGAD.A2007238.h08v06.005.2007241220231.hdf,
MYDPTHKM.A2007238.h08v06.005.2007241220212.hdf,
MYD09GHK.A2007239.h08v06.005.2007242063652.hdf,
MYD09GST.A2007239.h08v06.005.2007242062321.hdf,
MYDMGGAD.A2007239.h08v06.005.2007242061831.hdf,
MYDPTHKM.A2007239.h08v06.005.2007242061807.hdf,
MYD09GHK.A2007240.h08v06.005.2007243171012.hdf,
MYD09GST.A2007240.h08v06.005.2007243163242.hdf,
MYDMGGAD.A2007240.h08v06.005.2007243162538.hdf,
MYDPTHKM.A2007240.h08v06.005.2007243162420.hdf,
MYD09GHK.A2007241.h08v06.005.2007244032741.hdf,
MYD09GST.A2007241.h08v06.005.2007244031447.hdf,
MYDMGGAD.A2007241.h08v06.005.2007244031225.hdf,
MYDPTHKM.A2007241.h08v06.005.2007244031153.hdf,
MYD09GHK.A2007242.h08v06.005.2007245045319.hdf,
MYD09GST.A2007242.h08v06.005.2007245044223.hdf,
MYDMGGAD.A2007242.h08v06.005.2007245044003.hdf,
MYDPTHKM.A2007242.h08v06.005.2007245043924.hdf,
MYD09GHK.A2007243.h08v06.005.2007248143434.hdf,
MYD09GST.A2007243.h08v06.005.2007248141504.hdf,
MYDMGGAD.A2007243.h08v06.005.2007248141209.hdf,
MYDPTHKM.A2007243.h08v06.005.2007248141126.hdf,
MYD09GHK.A2007244.h08v06.005.2007247091119.hdf,
MYD09GST.A2007244.h08v06.005.2007247085633.hdf,
MYDMGGAD.A2007244.h08v06.005.2007247085455.hdf,
MYDPTHKM.A2007244.h08v06.005.2007247085421.hdf,
MYD09GHK.A2007245.h08v06.005.2007248012609.hdf,
MYD09GST.A2007245.h08v06.005.2007248010721.hdf,
MYDMGGAD.A2007245.h08v06.005.2007248010541.hdf,
MYDPTHKM.A2007245.h08v06.005.2007248010452.hdf,
MYD09GHK.A2007246.h08v06.005.2007255083102.hdf,
MYD09GST.A2007246.h08v06.005.2007255080900.hdf,
MYDMGGAD.A2007246.h08v06.005.2007255080648.hdf,
MYDPTHKM.A2007246.h08v06.005.2007255080556.hdf,
MYD09GHK.A2007247.h08v06.005.2007255150756.hdf,
MYD09GST.A2007247.h08v06.005.2007255145310.hdf,
MYDMGGAD.A2007247.h08v06.005.2007255145221.hdf,
MYDPTHKM.A2007247.h08v06.005.2007255145154.hdf,
MYD09GHK.A2007248.h08v06.005.2007251075702.hdf,
MYD09GST.A2007248.h08v06.005.2007251073308.hdf,
MYDMGGAD.A2007248.h08v06.005.2007251072953.hdf,
MYDPTHKM.A2007248.h08v06.005.2007251072857.hdf,
MOD09GHK.A2007233.h08v06.005.2007235222725.hdf,
MOD09GST.A2007233.h08v06.005.2007235222419.hdf,
MODMGGAD.A2007233.h08v06.005.2007235221909.hdf,
MODPTHKM.A2007233.h08v06.005.2007235221903.hdf,
MOD09GHK.A2007234.h08v06.005.2007237152604.hdf,
MOD09GST.A2007234.h08v06.005.2007237151838.hdf,
MODMGGAD.A2007234.h08v06.005.2007237151735.hdf,
MODPTHKM.A2007234.h08v06.005.2007237151701.hdf,
MOD09GHK.A2007235.h08v06.005.2007238032257.hdf,
MOD09GST.A2007235.h08v06.005.2007238025353.hdf,
MODMGGAD.A2007235.h08v06.005.2007238024639.hdf,
MODPTHKM.A2007235.h08v06.005.2007238024610.hdf,
MOD09GHK.A2007236.h08v06.005.2007239095547.hdf,
MOD09GST.A2007236.h08v06.005.2007239093658.hdf,
MODMGGAD.A2007236.h08v06.005.2007239093428.hdf,
MODPTHKM.A2007236.h08v06.005.2007239093339.hdf,
MOD09GHK.A2007237.h08v06.005.2007241025632.hdf,
MOD09GST.A2007237.h08v06.005.2007241023754.hdf,
MODMGGAD.A2007237.h08v06.005.2007241022546.hdf,
MODPTHKM.A2007237.h08v06.005.2007241022455.hdf,
MOD09GHK.A2007238.h08v06.005.2007241172628.hdf,
MOD09GST.A2007238.h08v06.005.2007241170539.hdf,
MODMGGAD.A2007238.h08v06.005.2007241170139.hdf,
MODPTHKM.A2007238.h08v06.005.2007241170109.hdf,
MOD09GHK.A2007239.h08v06.005.2007242074424.hdf,
MOD09GST.A2007239.h08v06.005.2007242073724.hdf,
MODMGGAD.A2007239.h08v06.005.2007242073630.hdf,
MODPTHKM.A2007239.h08v06.005.2007242073603.hdf,
MOD09GHK.A2007240.h08v06.005.2007243010525.hdf,
MOD09GST.A2007240.h08v06.005.2007243005546.hdf,
MODMGGAD.A2007240.h08v06.005.2007243005454.hdf,
MODPTHKM.A2007240.h08v06.005.2007243005432.hdf,
MOD09GHK.A2007241.h08v06.005.2007243231514.hdf,
MOD09GST.A2007241.h08v06.005.2007243230431.hdf,
MODMGGAD.A2007241.h08v06.005.2007243230150.hdf,
MODPTHKM.A2007241.h08v06.005.2007243230128.hdf,
MOD09GHK.A2007242.h08v06.005.2007245005400.hdf,
MOD09GST.A2007242.h08v06.005.2007245005018.hdf,
MODMGGAD.A2007242.h08v06.005.2007245004930.hdf,
MODPTHKM.A2007242.h08v06.005.2007245004922.hdf,
MOD09GHK.A2007243.h08v06.005.2007246020004.hdf,
MOD09GST.A2007243.h08v06.005.2007246014726.hdf,
MODMGGAD.A2007243.h08v06.005.2007246014636.hdf,
MODPTHKM.A2007243.h08v06.005.2007246014609.hdf,
MOD09GHK.A2007244.h08v06.005.2007246230653.hdf,
MOD09GST.A2007244.h08v06.005.2007246230243.hdf,
MODMGGAD.A2007244.h08v06.005.2007246230200.hdf,
MODPTHKM.A2007244.h08v06.005.2007246230151.hdf,
MOD09GHK.A2007245.h08v06.005.2007248090138.hdf,
MOD09GST.A2007245.h08v06.005.2007248083920.hdf,
MODMGGAD.A2007245.h08v06.005.2007248083721.hdf,
MODPTHKM.A2007245.h08v06.005.2007248083636.hdf,
MOD09GHK.A2007246.h08v06.005.2007249085420.hdf,
MOD09GST.A2007246.h08v06.005.2007249085024.hdf,
MODMGGAD.A2007246.h08v06.005.2007249084940.hdf,
MODPTHKM.A2007246.h08v06.005.2007249084929.hdf,
MOD09GHK.A2007247.h08v06.005.2007250003123.hdf,
MOD09GST.A2007247.h08v06.005.2007250002054.hdf,
MODMGGAD.A2007247.h08v06.005.2007250001916.hdf,
MODPTHKM.A2007247.h08v06.005.2007250001853.hdf,
MOD09GHK.A2007248.h08v06.005.2007250212413.hdf,
MOD09GST.A2007248.h08v06.005.2007250205836.hdf,
MODMGGAD.A2007248.h08v06.005.2007250204928.hdf,
MODPTHKM.A2007248.h08v06.005.2007250204904.hdf,
BRDF_DB.A2001001.h08v06.002.2005235120000.hdf
  GRINGPOINTLONGITUDE=-106.396225638704, -115.470053824421,
-103.573541793307, -95.4407395216898
  GRINGPOINTLATITUDE=19.8904251675885, 29.9999999973059,
30.0494066701966, 19.9379472075091
  PGEVERSION=5.0.11
  QAPERCENTGOODQUALITY=30
  QAPERCENTOTHERQUALITY=41
  QAPERCENTNOTPRODUCEDOTHER=29
  HORIZONTALTILENUMBER=08
  VERTICALTILENUMBER=06
  TileID=51008006
  SETUPFILEID=6121997
  PERCENTLANDINTILE=95.056002
  PERCENTPROCESSEDINTILE=83.268062
  PERCENTNEWBRDFS=41.880168
  PERCENTSHAPEFIXEDBRDFS=41.387894
  AVERAGENUMBEROBS=6.733127
  WESTBOUNDINGCOORDINATE=-115.470053824421
  NORTHBOUNDINGCOORDINATE=29.9999999973059
  EASTBOUNDINGCOORDINATE=-95.7671313650353
  SOUTHBOUNDINGCOORDINATE=19.9999999982039
  DATACOLUMNS=2400
  DATAROWS=2400
  NUMBEROFGRANULES=0
  PROCESSINGENVIRONMENT=Linux minion5083 2.6.8.1-26mdksmp #1 SMP Mon Nov
28 12:40:04 MST 2005 i686 IntelR XeonTM CPU 2.80GHz unknown GNU/Linux
  DESCRREVISION=5.1
  _FillValue=32767
  scale_factor=0.0001
  add_offset=0
  scale_factor_err=0
  add_offset_err=0
  calibrated_nt=5
Corner Coordinates:
  NoData Value=32767
tile h18 v09 : not added because it makes my message too large
