[Gdal-dev] modis sinusoidal tiles: bug in gdal?
Christopher Barker Chris.Barker at noaa.gov
Tue Nov 6 12:26:38 EST 2007
Vincent Schut wrote:
> - md says CHARACTERISTICBINSIZE=463.312716527778
> - (6371007.181 * 2pi) / 86400 = 463.31271656938469
> Now which one is non-accurate, their spheroid or their pixel size?
These are the same to single precision floating point -- was all
storage/calculation done in doubles? I expect not. We all know that
checking equality is problematic with floating point -- all you can do
is check that they are the same to the precision expected, and this sure
looks close to me.
looking closer, they are the same for the first 10 decimal digits, and
your calculation is based on ten digits input.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
