[Gdal-dev] RE: How to efficiently read in a GDAL image into a
matrix
Christopher Barker
Chris.Barker at noaa.gov
Wed Nov 7 17:09:06 EST 2007
Nate Jennings wrote:
> You might try my website below, then go to Skillset--Application
> Development. I just put up a python script to do a mean filter on a
> multiband image. It uses the python gdal build of 1.4.2 that is
> posted on the gdal site and also requires the old Numeric libraries
> as well.
You should be able to do it with the latest GDAL and numpy as well.
> I do access individual pixels. The code runs very slow (~5 min for a
> 400 x 600 image).
Is it necessary to do by individual pixels? numpy gives you a lot of
tools to work with whole arrays at a time, which would make it MUCH
faster. There are also a fair number of image processing algorithms out
there that use numpy -- ask on the numpy list if you can't find what you
need.
> I am looking to reproduce a similar function using c++ if and when I
> can understand how the gdal libraries are used within c++.
If you do really need to go to C/C++, another option is to write code
that works with numpy arrays as a python extension -- that way you can
still write everything else in Python. There are lots of way to write
C/C++ for use with numpy arrays:
SWIG
Pyrex
weave.blitz
f2py
See: http://www.scipy.org/PerformancePython
and the scipy and numpy lists for examples and discussion.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
