[Gdal-dev] PCI .pix: only reading 1 band
Sat Nov 10 15:50:59 EST 2007
Matt Wilkie wrote:
> Hi,
> In trying to do some stuff today I noticed that the gdal utilities are
> only reading a single band of PCI .pix images. Is this normal? Has it
> always been this way? I think I remember using gdal before on these but,
> as I've publicly proven here in the past my memory is not so reliable...
> GDAL 1.5dev, FWTools 1.4.2, released 2007/11/05
> Here is gdalinfo output for a 6 channel .pix:
Matt,
Multi band files should work.  I have confirmed that gdalinfo sees
multiple bands on an old "irvine.pix" file.  Could you submit a bug
report on this issue with a file causing problems?  (hopefully a small
file).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
