[Gdal-dev] Is make generate a part of make release?
Ari Jolma ari.jolma at tkk.fi
Sun Nov 11 05:41:35 EST 2007
Frank Warmerdam kirjoitti:
> If you would like the same done for perl, please update the
> mkgdaldist.sh script yourself.
I did this and tested it.
For the record, I needed to remove the dependency to GDALmake.opt from
GNUmakefile in swig/perl, which was only needed for INST_PREFIX to be
the PREFIX for perl Makefile.PL. Currently only "perl Makefile.PL" is
run, which puts the Perl module to a standard location. If somebody
needs to put them somewhere else they need to run "perl Makefile.PL" by
hand and specify "PREFIX=some_path" manually instead of through "make
build". If there's a big need for Perl PREFIX to be the INST_PREFIX of
GDAL automagically then maybe we can come up with some way of picking it
up from GDALmake.opt, but honestly, I don't think that's really needed.
Ari
Prof. Ari Jolma
Geoinformaatio- ja paikannustekniikka / Geoinformation and positioning
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
