[Gdal-dev] coordinates with gdal_array
sandric ionut sandricionut at yahoo.com
Tue Nov 13 09:10:17 EST 2007
Hello:
I am using gdal_array to read data as array, process the data, and write it back as raster data. When I save the array to raster, using any format supported by gdal, I loose the coordinates. How can I keep the coordinates after I process the array?
Thank you,
Ionut
      ____________________________________________________________________________________
Be a better sports nut!  Let your teams follow you
with Yahoo Mobile. Try it now.  http://mobile.yahoo.com/sports;_ylt=At9_qDKvtAbMuh1G1SQtBI7ntAcJ
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071113/32a16ac3/attachment.html
