[Gdal-dev] Old style ESRI prj files
Ethan Alpert ealpert at digitalglobe.com
Wed Nov 14 08:28:48 EST 2007
I'm still in the debugger looking at what is going on hopefully I'll
come up with something. For now, it seems [$prj] although it is the type
expected by the wrapper, causes pszItem to always be NULL when it
fetches the list of strings. So arg2 contains no data when calling
OSRSpatialReferenceShadow_ImportFromESRI
I'm going to have to read the perl guts docs to get a better idea of why
this is.
Here's an ESRI prj file:
PROJCS["WGS_1984_UTM_Zone_10N",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",
SPHEROID["WGS_1984",6378137,298.257223563]],PRIMEM["Gr
eenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_
Mercator"],PARAMETER["False_Easting",500000],PARAMETER
["False_Northing",0],PARAMETER["Central_Meridian",-123],PARAMETER["Scale
_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0],UNI
T["Meter",1]]
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Ari Jolma
Sent: Wednesday, November 14, 2007 12:29 AM
To: gdal-dev
Subject: [Gdal-dev] Old style ESRI prj files
The ImportFromESRI method of OSR SpatialReference takes a list of
strings as a parameter. Could somebody give me or point me to an example
of such a list?
Hobu, you changed the API of that method to use a correct typemap but it
seems that it miraculously worked earlier in the Perl bindings when it
was given the contents of a PRJ file in one string.
Cheers,
Ari
Prof. Ari Jolma
Geoinformaatio- ja paikannustekniikka / Geoinformation and positioning
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
