[Gdal-dev] Re: RFC 10
Mateusz Loskot mateusz at loskot.net
Thu Nov 15 13:04:30 EST 2007
Frank Warmerdam wrote:
> I'm not clear on why RFC 10 couldn't be altered to provide a standard
> mechanism to encode parameters into the datasource name and go from there.
> The issue of applications which don't know the format apriori is not new.
I think it might be not easy to find common syntax used across all
drivers. For example, if we decided to delimit options with @, perhaps
there are some drivers that use @ token in its native connection string.
IMO, options interface should be defined as common to all drivers, but
not using syntax specific to a driver.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
