[Gdal-dev] Re: RFC 10
Mateusz Loskot mateusz at loskot.net
Thu Nov 15 13:45:44 EST 2007
Frank Warmerdam wrote:
>>> I'm not clear on why RFC 10 couldn't be altered to provide a standard
>>> mechanism to encode parameters into the datasource name and go from
>>> there.
>>> The issue of applications which don't know the format apriori is not
>>> new.
>> I think it might be not easy to find common syntax used across all
>> drivers. For example, if we decided to delimit options with @, perhaps
>> there are some drivers that use @ token in its native connection string.
>> IMO, options interface should be defined as common to all drivers, but
>> not using syntax specific to a driver.
> Mateusz,
> Yes, that was my intent.  To "package" lists of options in a standard way
> with well understood escaping and quoting rules.  A mechanism that could
> be applied to new drivers, and in some hopefully not-too-disruptive fashion
> applied to old drivers with options in the datasource name.
Frank,
OK
Cheers
Mateusz Loskot
http://mateusz.loskot.net
