[Gdal-dev] Method to get an image by url?
Zhonghai Wang zhonghaiw at gmail.com
Thu Nov 15 16:50:04 EST 2007
Hi There,
try this:
> *gadlinfo "http://kh.google.com/kh?v=99&n=404&t=tqssrrqstt"*
be sure that you enclosed the http link with double quote.
Regards
Zhonghai
On Nov 15, 2007 10:29 PM, Joaquim Luis <jluis at ualg.pt> wrote:
> Sorry to insist on this but is libcurl support the only condition to
> access images by url?
> I'm able to access using FWTools but with my build 1.4.3 I get these
errors.
> And yes, I checked with the dependency walker that libcurl and zlib1
> etc... are all  "non red"
> Thanks
> Joaquim
> ERROR 4: `http://kh.google.com/kh?v=99&n=404&t=tqssrrqstt' does not
> exist in the
>  file system,
> and is not recognised as a supported dataset name.
> GDALOpen failed - 4
> `http://kh.google.com/kh?v=99&n=404&t=tqssrrqstt' does not exist in the
> file sys
> tem,
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071115/3d073b88/attachment.html
