[gdal-dev] OGRGeometry creation
Mateusz Loskot mateusz at loskot.net
Fri Nov 23 07:57:42 EST 2007
Yuriy Rusinov wrote:
> Dear Colleagues !
> I try to create geometry object using wkt-string. I do
>     OGRGeometry * poOGRGeom;
>     const char* obWkt = "POLYGON((...,...))";
>     char * pszWkt = new char [strlen (obWkt)];
You need strlen(obWkt) + 1, to have room for \0 character
>     strncpy (pszWkt, obWkt, strlen (obWkt));
>     OGRSpatialReference *ref = new OGRSpatialReference ();
Not necessary, you can pass NULL instead of empty SRS.
>     OGRErr ier = OGRGeometryFactory::createFromWkt (&pszWkt, ref,
> &poOGRGeom);
>     if (ier == OGRERR_NONE)
>         char ** wkt = new char*;
>         wkt[0] = new char[1000];
Here is the bug.
You don't need to allocate memory for output wkt.
The manual says:
"ppszDstText - a text buffer is allocated by the program, and assigned
to the passed pointer."
http://www.gdal.org/ogr/classOGRGeometry.html#71184265101d21cffa5c50ee79afdd61
>         poOGRGeom->exportToWkt (wkt);
> This code works fine under Linux, but under Windows (Visual Studio 2003) it
> fails on call of any function-member OGRGeometry class. Where is the
> troubles ?
This is random problem caused by incorrect (re)allocation of output
buffer pointed above. Here is complete code of your example that
presents how correctly import/export WKT to/from OGRGeometry:
#include <ogrsf_frmts.h>
#include <iostream>
#include <cstdlib>
#include <cassert>
int main()
    OGRRegisterAll();
    OGRGeometry * poOGRGeom = NULL;
    const char* obWkt = "POLYGON((0 0,4 0,4 4,0 4,0 0),(1 1,2 1,2 2,1
2,1 1))";
    // Copy WKT to new 'iteratable' buffer
    std::size_t size = strlen(obWkt);
    char * pszWkt = new char [size + 1];
    memset(pszWkt, 0, size);
    strncpy(pszWkt, obWkt, size);
    // You don't need this, you can pass NULL
    // if you do not need specific SRS
    // Use copy of ptr, as we need the original for deallocation
    // createFromWkt uses passed WKT ptr as iterator, so it will point
    // to pass-the-end after all
    char* p = pszWkt;
    OGRErr ier = OGRGeometryFactory::createFromWkt (&p, ref, &poOGRGeom);
    delete [] pszWkt;
        // exportToWkt will allocate memory for WKT
        char* wkt = NULL;
        poOGRGeom->exportToWkt(&wkt);
        assert(NULL != wkt);
        std::cout << wkt << std::endl;
        // Important cleanup
        CPLFree(wkt);
    OGRGeometryFactory::destroyGeometry(poOGRGeom);
    return 0;
Cheers
Mateusz Loskot
http://mateusz.loskot.net
