[gdal-dev] problem with dstnodata and vrt in gdalwarp
fabrice martin fabrice_martin2 at yahoo.fr
Fri Nov 23 15:19:35 EST 2007
Hello,
I have a problem using dstnodata when the input is a vrt file: it
looks as if dstnodata is not taken into account. Indeed, if I choose destination coordinates that are not completely overlapped by the source images, nodata areas are
always black, whatever the value for dstnodata.
For example, I create a simple vrt with gdal_vrtmerge:
gdal_vrtmerge.py -o test.vrt *.tif
If I reproject this vrt, nodata
areas are black:
gdalwarp -of Gtiff -te 897000 6657000 898000 6658000 -s_srs
"EPSG:27582" -t_srs "EPSG:2154" -tps -rc -tr 0.5 0.5 -dstnodata 255 -co INTERLEAVE=PIXEL test.vrt test_with_vrt.tif
If I reprojet directly
the same *.tif images, nodata areas are white as expected:
gdalwarp -of
GTiff -te 897000 6657000 898000 6658000 -s_srs "EPSG:27582" -t_srs
INTERLEAVE=PIXEL
*.tif test_with_tifs.tif
Could you confirm the problem ? If so, do you have any
insight on where to look in the code to correct it ?
Thank
you,
Fabrice.
      _____________________________________________________________________________
Ne gardez plus qu'une seule adresse mail ! Copiez vos mails vers Yahoo! Mail
