[gdal-dev] HDF4 trouble files
Sun Nov 25 17:03:09 EST 2007
Joaquim Luis wrote:
> OK
> Excuse me guys, it was a false error report. I was used to load the
> color files with no problem and I got hanged with the sst ones
> ... but I still have this other situation
> This file reports 0s for all X's
> http://oceancolor.gsfc.nasa.gov/cgi/getfile/S20061822006212.L3m_MO_L555_9.bz2
> It may obviously be a file's internal error. but I have no way to tell it.
> Corner Coordinates:
> Upper Left  (       0.000,10018754.171) (  0d 0'0.01"E, 90d 0'0.00"N)
> Lower Left  (       0.000,-10018754.171) (  0d 0'0.01"E, 90d 0'0.00"S)
> Upper Right (       0.000,10018754.171) (  0d 0'0.01"E, 90d 0'0.00"N)
> Lower Right (       0.000,-10018754.171) (  0d 0'0.01"E, 90d 0'0.00"S)
> Center      (   0.0000000,   0.0000000) (  0d 0'0.01"E,  0d 0'0.01"N)
Joaquim,
I have confirmed this problem.  It turns out to be a problem transforming
the world corners (-180,90) to equirectangular.  Due to complex internal
issues it is hard to do this properly for projections that are internally
treated as spherical.  Grr.
Could you file a ticket on this issue?
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
