[gdal-dev] Successful warping of MODIS surface reflectance products from sinusoidal to HGRS87
nikos.alexandris at felis.uni-freiburg.de nikos.alexandris at felis.uni-freiburg.de
Wed Nov 28 07:37:13 EST 2007
I hope this time my mail comes through till the GDAL mail
-list ;-)
(Re-post!  Sorry, I was trying to post this through Nabble
since the
22th of November. Yet, it was not accepted all this days...
Just FYI:
Yoohooo!
Many many thanks to all... !!
The answer was in: http://trac.osgeo.org/gdal/ticket/1239
[  $ gdalwarp -of HFA \
    -s_srs '+proj=sinu +R=6371007.181 +nadgrids=@null
+wktext' \ -t_srs
TARGET-SRS \
'HDF4_EOS:EOS_GRID:"fpar8.hdf":MOD_Grid_MOD15A2:Fpar_1km'
fpar8.hfa
        Note the key `+nadgrids=@null +wktext' options. In
TARGET-SRS,
+ellps=sphere' becomes unnecessary (unless, of course, one
wants the
dataset to be warped into a projection on a sphere.)  ]
(Using Markus script ...slighlty modified, using 460x460
pixel
resolution for the output):
#!/bin/sh
#MODIS HDF/Sinusoidal to GeoTiff/HGRS87
#Based on:
#2005, Markus Neteler
# warp MODIS HDF to Erdas/Img - LatLong/WGS84
PROG="$0"
if [ $# -lt 1 -o "$1" = "-h" -o "$1" = "--help" -o "$1" =
"-help" ] ;
then
 echo "Script to warp all layers of MODIS HDF to Erdas/Img
LatLong/WGS84"
 echo "Usage:"
 echo "      $PROG M[OD|MYD]blablabla.hdf"
 exit 1
fi
FILE=$1
HDFlayerNAMES="`gdalinfo $FILE | grep SUBDATASET_ | grep
_NAME | cut
-d'=' -f2`"
#aarg! NDVI/EVI MOD13 contains spaces:
HDFlayerNAMES_NOSPACES="`gdalinfo $FILE | grep SUBDATASET_
| grep _NAME
| cut -d'=' -f2 | tr -s ' ' '|'`"
#MODIS does not use the "Normal Sphere (r=6370997)"!!!
# MODIS sphere, radius of 6371007.181 --> Instead use:
'+proj=sinu
+R=6371007.181 +nadgrids=@null +wktext'
http://edcdaac.usgs.gov/landdaac/tools/mrtswath/info/ReleaseNotes.pdf
#GGRS87 (or HGRS87 or EGSA87)
#<2100> +proj=tmerc +lat_0=0 +lon_0=24 +k=0.9996
+x_0=500000 +y_0=0
+ellps=GRS80 +towgs84=-199.87,74.79,246.62,0,0,0,0 +units=m
+no_defs <>
#loop over all layers:
for i in ${HDFlayerNAMES_NOSPACES} ; do
        #transform back:
        INPUT="`echo ${i} | tr -s '|' ' '`"
        NEWNAME="`echo ${i} | cut -d':' -f4,5 | tr ':' '_'
| tr -s '|'
'_'`"
        # apply GCPs
        gdalwarp -s_srs '+proj=sinu +R=6371007.181
+nadgrids=@null
+wktext' -t_srs '+init=epsg:2100' -tr 460 460 "${INPUT}"
$NEWNAME.HGRS87.tif
done
Nikos Alexandris
Department of Remote Sensing & Landscape Information
Systems
Faculty of Forestry & Environmental Sciences,
Albert-Ludwigs-University Freiburg
Tel.  +49 (0) 761 203 3697 / Fax.  +49 (0) 761 203 3701 /
Skype: Nikos.Alexandris
Address: Tennenbacher str. 4, D-79106 Freiburg i. Br.,
Germany
