[Gdal-dev] Ogr and Postgis support
Christopher Barker Chris.Barker at noaa.gov
Mon Oct 1 13:36:08 EDT 2007
Brian Hamlin wrote:
> For python, I have since upgraded to 2.5.1, leaving me with two
> python installs, which causes me grief now and then. But basically,
> the GDAL bindings work fine.
Which python are you using them with? Apple's 2.3 is a bit broken (I
think mostly for GUI apps though), and the consensus among most
MacPython folks is that it is best to use one of the newer "framework"
builds -- 2.4 or 2.5.
> I installed Numeric and that works fine.
Numeric is generally still working, but it is no longer supported, and I
think has a couple issues with 2.5 -- going to numpy is a good idea.
> I do not follow the talk of NumPy and new Python bindings.
Both numpy and the NG bindings are the way to go into the future. The NG
bindings are getting attention now, and work great. I'm not sure when
they will become the default -- maybe 1.5-- Frank?
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
