[Gdal-dev] Issue with 1.4.2 gdalwarp
nashirak nashirak at gmail.com
Tue Oct 2 15:40:37 EDT 2007
I was looking into why the 1.4.2 version of GDAL seemed to remove the
geospatial information when attempting to rotate the image to north up.  I
ran across this post:
http://lists.maptools.org/pipermail/gdal-dev/2007-June/013287.html
I downloaded FWTools 1.3.7, as suggested here
http://lists.maptools.org/pipermail/gdal-dev/2007-June/013290.html,  and
tried to use the gdalwarp that came with the FWTools package.  This program
did not remove the geospatial information and gave me a correct result.  Is
there a fix for this in a later GDAL version?  What version of GDAL was
FWTool 1.3.7 compiled against?
Thanks.
Clayton Bluhm
Home: nashirak at gmail.com
"si vis pacem para bellum" -- Vegetius
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071002/d434ade6/attachment.html
