[Gdal-dev] Re: Issue with 1.4.2 gdalwarp
Wed Oct 3 11:14:30 EDT 2007
On 10/3/07, nashirak <nashirak at gmail.com> wrote:
> > Clayton,
> > FWTools 1.3.7 is built against GDAL "trunk" as of the time it was
> > built (not GDAL 1.4.x).
> Does this mean that I pull from the current Subversion trunk to get the fix,
> or was the fix built against an older version of the subversion trunk?
Clayton,
1.3.7 was built against GDAL trunk as of a few weeks ago, but
presumably whatever fixed things will also be in the current
trunk.
Best regards,
