[Gdal-dev] Building on Windows with Python 2.5
Howard Butler hobu.inc at gmail.com
Wed Oct 3 14:04:39 EDT 2007
To build the next-gen Python bindings for GDAL (assuming the current
trunk here) you need to have the following settings in your nmake.opt:
- SWIG must be set to the location of your swig install.  1.3.31 is
required
- PY_DIR must be set so it can find python.exe
Additionally, these items should be done:
- GDAL must already be made by doing 'nmake /f makefile.vc' in the
root of the GDAL source directory
- Numpy should already be installed in the python you are using with
PY_DIR
- Having setuptools installed might be advantageous, but not required
After these conditions are met, cd into ./swig and issue 'nmake /f
makefile.vc python'. This command will regenerate the bindings with
swig and build the module.  After it is built, you can cd into ./swig/
python and issue 'python setup.py bdist_wininst' to have it build a
windows installer that will end up in ./swig/python/dist, or 'python
setup.py bdist' to have it build a zip distribution.
Howard
On Oct 3, 2007, at 9:59 AM, Rob McCulley wrote:
> Hi All,
> I’m trying to make the migration to Python version 2.5.  In the
> past, I’ve been lazy, and just the MS4W version of the GDAL python
> bindings.  They are compiled for Python 2.4 though, so I’ve been
> trying to build GDAL and the Python bindings for version 2.5
> without much success.  I’m working with the GDAL version 1.4.2
> source code and compiling with MSVC2003 (7.1).
> The build runs just fine, as far as I can see.  There don’t appear
> to be any errors.  The bin directory is populated with all the
> utility programs, various python scripts, the data directory, the
> html directory and the pymod directory.  As far as I can see the
> utility programs run fine.  When I copy the contents of the pymod
> directory over to the site-packages directory in Python25 and try
> and import gdal I get the following error:
> Traceback (most recent call last):
>   File "<interactive input>", line 1, in <module>
>   File "C:\Python25\lib\site-packages\gdal.py", line 191, in <module>
>     import _gdal
> ImportError: No module named _gdal
> As a test, I compiled gdal against Python 2.4, and everything
> worked fine.  The python modules imported without error.  Any ideas
> on what to do to get it working with 2.5?  Is this a problem with
> having both 2.4 and 2.5 installed on the system?
> Alternatively, this seems like as good a time as any to move over
> to the next generation bindings.  How does one go about building
> the NG bindings with MSVC2003?
> Thanks,
> Rob McCulley
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
