[Gdal-dev] Re: GIF
Thu Oct 4 13:16:37 EDT 2007
Joaquim Luis wrote:
> Frank Warmerdam wrote:
>> On 10/4/07, cincirin <cincirin at gmail.com> wrote:
>>> Thanks for your fast answer, but now I have another little question.
>>> Suppose
>>> the GIF are handled only 1 byte palette, GDALOpen return for example
>>> 6, 10,
>>> etc. bands for animated GIF. Are these bands represent only one frame(
>>> image ) in animated gif ?
>> Cincirin,
>> I checked a couple gifs that I believe are animated and they
>> only have one band, so to the best of my knowledge animated
>> gifs are not represented as multi-band .  If you find a gif with
>> multiple bands in GDAL then I'd appreciate seeing it.
> Frank,
> The attached gif (if it passes) was produced by a program of mine.
> gdalinfo says  it is multiband.
Joaquim,
I stand corrected.  It does appear that each animation step is a
band, but there is no mechanism in the current driver to expose the
delay between steps.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
