[Gdal-dev] OGR and the version of DBF of its shapefile driver, problem in ArcGIS 8
Thu Oct 4 14:19:38 EDT 2007
Ari Jolma wrote:
> Greetings,
> I think I've hit this problem with ArcGIS 8.*:
> http://support.esri.com/index.cfm?fa=knowledgebase.techarticles.articleShow&d=21487
> dbfdump reports that the dbf files that I've created with OGR are
> version 0x03 and I haven't seen dbf files that are a part of shapefiles,
> which are of other versions.
Ari,
I checked the dbf specs at:
   http://www.clicketyclick.dk/databases/xbase/format/dbf.html#DBF_STRUCT
It indicates that 0x03 is "File without DBT" whatever that means, but it
is the same dbf version code I found many years ago in ESRI supplied .dbf
files.
> The shapefiles I've created with OGR are readable with ArcView 3.* and
> if I resave the dbf there, it can be opened with ArcGIS 8.*
It might be instructive if you would provide the before and after .dbf
files for review.
I don't have ArcGIS so it is hard for me to test, but I haven't heard
of much in the way of problems like this.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
