[Gdal-dev] Motion to Adopt RFC 16: OGR Thread Safety
mchapman at texelinc.com mchapman at texelinc.com
Sat Oct 6 13:43:37 EDT 2007
I agree.  Adding mt to gdal should be done at the application level.  That's what I do today and it works great.  You could also consider thread safe wrapper classes instead of modifying the core.  Simon's idea of a lock/unlock is good too.
Martin
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Sat, 06 Oct 2007 11:17:01
To:Frank Warmerdam <warmerdam at pobox.com>
Cc:gdal-dev <gdal-dev at lists.maptools.org>
Subject: Re: [Gdal-dev] Motion to Adopt RFC 16: OGR Thread Safety
For some reason I missed or ignored the original posting of this RFC. I
have a late comment / question...
What about methods that modify a layer? i.e. we have two threads, A and
B accessing the same layer via layer clones, so they each have their own
read state. What if thread A checks to see if a feature with FID 42
exists, then B invokes a method to delete feature 42, before thread B
attempts to get the geometry for that feature? Even if those calls are
serialized, it is likely that thread A will get very confused.
I think in general, guaranteeing thread safety when you have threads
modifying data is in general extremely hard at the library level, and
really requires some kind of thread coordination at the application
program level. Maybe the datasource mutex could be exposed with a couple
of handy Lock/Unlock methods to make this kind of high level
coordination easier? In any case, shouldn't the RFC mention something
about reading vs writing?
Cheers,
Simon
Frank Warmerdam wrote:
> Motion: To adopt RFC 16: OGR Thread Safety
> http://trac.osgeo.org/gdal/wiki/rfc16_ogr_reentrancy
> There wasn't to much discussion on this as far as I recall, which I take
> to mean no one has a problem with it.  So moving to formal vote so I can
> implement this coming week.
> +1 from me.
> Best regards,
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
