[Gdal-dev] Read hdf band, inverse dimensions
    Jan Cermak
    jcermak at atmos.washington.edu
    Mon Oct  8 20:16:35 EDT 2007
Lucena,
Thanks for the suggestion, I will try that. However, I would really like
to find a way to all this from within python, without external tools and
without any reprojection. Does anybody know a way of doing this?
Jan
Lucena, Ivan wrote:
> Jan,
> I once had a problem just like that and the solution was to
> translate/project the data to geotiffs using "Modis Swath Reprojection
> Tool" and then go back to GDAL to work with the tifs.
> Ref.: [http://edcdaac.usgs.gov/landdaac/tools/mrtswath/]
> Good luck,
> Ivan
> Jan Cermak wrote:
>> Hi!
>> I am trying to read a band from a MODIS hdf file. This in itself does
>> not seem to be a problematic thing to do; however, the dimensions of
>> the array are inverse.
>> gdalinfo myfile.hdf (or gdal.Dataset.GetSubDatasets) yields:
>> [snip]
>> SUBDATASET_52_NAME=HDF4_EOS:EOS_SWATH:'myfile.hdf':mod06:Cloud_Mask_1km
>> SUBDATASET_52_DESC=[2040x1354x2] Cloud_Mask_1km mod06 (8-bit integer)
>> [snip]
>> So there are two bands of size 2040x1354 in my subdataset. However, in
>> order for gdal to recognize them as two bands the dimensions would
>> have to be [2x2040x1354].
>> Accordingly, when I do
>> gdalinfo HDF4_EOS:EOS_SWATH:'myfile.hdf':mod06:Cloud_Mask_1km
>> I get information on 2040 different bands, each of size 1354x2
>> What can I do to get my two bands? I know I could read 2040 datasets
>> and then reassemble them. But that takes 2/3 eternity.
>> All help appreciated!
>> Jan
