[Gdal-dev] HDF EOS segmentation fault
Tue Oct 9 13:16:58 EDT 2007
Jan Cermak wrote:
> Hi,
> When I read in an hdfeos dataset from a MYD06 file I get a segfault of the following type:
> *** glibc detected *** python: double free or corruption (fasttop): 0x081b8d90 ***
> This occurs either at one of the steps following the data read or at the termination of the program. There does not seem to be a pattern. Here is some example code:
> #!/usr/bin/env python
> import gdal
> DSname='HDF4_EOS:EOS_SWATH:"/home/jancer/data/tmp/MODIS/MYD06_L2.A2006220.1315.005.2006222153137.hdf":mod06:Cloud_Optical_Thickness'
> DSobj = gdal.Open(DSname)
> data = DSobj.ReadAsArray()
> data.shape
> halfdata = data/2.
> There is a sample file at
> ftp://ladsweb.nascom.nasa.gov/allData/5/MYD06_L2/2006/220/MYD06_L2.A2006220.1315.005.2006222153137.hdf
Jan,
I believe you are experiencing one of several bugs that have been fixed
in the last six months or so in GDAL's HDF driver.  Can you update to
either a 1.4 branch snapshot or a trunk snapshot from:
  http://download.osgeo.org/gdal/daily
and see if the problem still persists? (or perhaps grab a recent FWTools
build).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
