[Gdal-dev] FW: HDF Newsletter #96 (release of HDF 4.2r2)
Lucena, Ivan ivan.lucena at pmldnet.com
Tue Oct 9 21:17:40 EDT 2007
Apologies for cross-posting.
It is about the release of HDF 4.2r2.
Best regards,
Ivan
  -----Original Message-----
  Sent: Tuesday, October 09, 2007 3:14 PM
  To: news at hdfgroup.org
  Subject: HDF Newsletter #96
  THG Home Page:                   http://hdfgroup.org/
  Helpdesk & Mailing Lists Info:
  http://hdfgroup.org/services/support.html
                               Newsletter #96
                              October 9, 2007
  CONTENTS
    . Release of HDF 4.2r2
      - New Features and Changes
      - Platforms Tested
      - Known Problems
  We are pleased to announce the release of HDF 4.2r2. It
  can be downloaded from the following location:
       http://hdfgroup.org/release4/obtain.html
  The HDF 4 web page is located at:
       http://hdfgroup.org/products/hdf4/index.html
  Not all of the pre-compiled binaries have been generated for
  HDF 4.2r2.  They should be available within the next week.
  The documentation for HDF 4.2r2 can be obtained from:
       http://hdfgroup.org/doc.html
  The RELEASE.txt file in the source code contains detailed
  information about this release:
       ftp://ftp.hdfgroup.org/HDF/HDF_Current/src/RELEASE-4.2r2.txt
  o Several new APIs have been added to the SD and GR interfaces:
     + SDreset_maxopenfiles, SDget_maxopenfiles, SDget_numopenfiles:
       For modifying and checking the maximum allowed number of files.
     + SDgetcompinfo, GRgetcompinfo: Gets compression information. These
       functions replaced SDgetcompress and GRgetcompress.
     + SDgetfilename: Retrieves the name of the file, given its ID.
     + SDgetnamelen: Retrieves the length of an object's name, given its
  ID.
  o SZIP compression has been added for Fortran, and SZIP compression has
     also been added to the GR interface.
  o The problem has been fixed where corruption could occur when a
  1-Dimensional
     SDS had the same name as a dimension.  However, be aware that:
     + It is impossible to recover the data that was already corrupted.
     + For existing data that has not been corrupted, the problem was
       fixed for multi-dimensional SDSs only.  If the SDS had only one
       dimension, the results of subsequent accesses to the dimension
       would still be unpredictable.
  o SDS and Vgroup names are no longer limited to 64 characters.
  o The maximum number of files that can be opened at the same time is
     no longer limited to 32.  In this release, if this limit is reached,
  the
     library will increase it to the system limit, minus 3 to account for
  stdin,
     stdout, and stderr.
  o A command-line option (-u) was added to ncdump to enable a user to
     replace non-alphanumeric characters in SDS names with underscores, if
     desired.  The default behavior is to print what is actually in the
  file.
  o New error codes were added to the HDF library.  Please refer to the
     RELEASE.txt file and other HDF4 documentation for more information.
  o Several new platforms are supported: Mac Intel, FreeBSD 64-bit,
     Solaris 10 Intel, Linux 2.6 and HP-UX 11.23 (32-bit, 64-bit).
  o Several changes were made to the HDF configuration, including:
     . The --enable-netcdf flag was introduced.
     . The autotools versions were updated.
  o Many bugs have been fixed in hrepack and hdiff.
  Please refer to the RELEASE.txt file for a comprehensive list of
  changes in this release.
  Platforms Tested
  Platforms that were tested with this release are:
      AIX 5.3 (32-bit, 64-bit)
      Free BSD 6.2 (32-bit, 64-bit)
      HP-UX B.11.23 (32-bit, 64-bit)
      IRIX 64 v6.5 (32-bit, 64 bit)
      Linux 2.4, 2.6
      Linux ia64
      Linux x86_64
      Sun OS 5.8, 5.10 (32-bit, 64-bit)
      Windows XP, Vista
      Mac OS X Intel
  For detailed information on platforms and compilers, please
  refer to the RELEASE.txt file.
  Known Problems
  o  hdfcomp fails on HPUX 11.23 for the 64-bit version of the library
  o  This release does not support VMS systems.
  o  N-Bit compression is not supported with Fortran APIs.
  o  Using both fill-value and compression at the same time on an SDS
      does not work.
  o  When using PGI compilers, make sure that the JPEG library is also
  compiled
      with a PGI C compiler; linking with JPEG built with gcc causes JPEG
  library
      tests to fail.  To bypass the problem:
          x Set LIBS flag to $PGI_JPEG_INSTALL_DIR/lib/libjpeg.a
            where $PGI_JPEG_INSTALL_DIR points to the installation
  directory
            for the PGI-compiled JPEG library:
            setenv LIBS $PGI_JPEG_INSTALL_DIR/lib/libjpeg.a
          x Use the --with-jpeg=$PGI_JPEG_INSTALL_DIR configure flag to
            configure with the PGI-compiled JPEG library:
            ./configure --with-jpeg=$PGI_JPEG_INSTALL_DIR --with-zlib....
  This mailing list is for news regarding HDF.
  To subscribe to this list, send a message to
  news-subscribe at hdfgroup.org.
  To unsubscribe, send a message to news-unsubscribe at hdfgroup.org.
