[Gdal-dev] How to Create a Geometry Filter
Kent Eschenberg eschenbe at psc.edu
Wed Oct 10 17:03:12 EDT 2007
Greetings,
This is a combination complaint/question. I'm trying to use the layer classes'
  geometry filter to select only features in an area bounded by 4 points.
I can't do that directly but must use SetSpatialFilter and first create an
instance of OGRPolygon. I do so and look for a way to set the polygon's points.
I can't do that directly but must use addRing and first create an instance of
OGRLinearRing. I do that and look for a way to set the ring's points.
I can't do that directly but must use importFromWkb and first create a buffer
of "the well known binary data".
Perhaps it is well known in an alternate universe but I can't find it anywhere
in the documentation that came with the GDAL library.
Being a good programmer I looked at ogrlinearring.cpp for the routine
"importFromWkb". All it does is return
    OGRERR_UNSUPPORTED_OPERATION
That doesn't look promising but I also found an undocumented routine hiding in
that file, _importFromWkb, which doesn't even bother to claim that its "stream
buffer" input is well known.
Is this the best thing to do? To create a "stream buffer" to create a "ring" to
create a polygon to create a filter for a layer?
I should document this adventure in a file named "wild_goose_chase.shp".
Kent
Pittsburgh Supercomputing Center
