[Gdal-dev] gdalinfo fails to report all info on netCDF file that resides in a different partition (Windows)
Joaquim Luis jluis at ualg.pt
Sat Oct 13 09:43:36 EDT 2007
The below two listings are self explanatory of the problem
In the first case I run grdinfo from D:\.. applied to a file which is C:\
In the second case I run C:\
D:\SVN\mironeWC>gdalinfo c:\arc_netcdf.nc
Driver: netCDF/Network Common Data Format
Size is 512, 512
Coordinate System is `'
Metadata:
  NC_GLOBAL#Conventions=CF-1.0
  NC_GLOBAL#Source_Software=ESRI ArcGIS
Subdatasets:
  SUBDATASET_1_NAME=NETCDF:"c:\arc_netcdf.nc":z_Layer
  SUBDATASET_1_DESC=[421x541] z_Layer (32-bit floating-point)
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  512.0)
Upper Right (  512.0,    0.0)
Lower Right (  512.0,  512.0)
Center      (  256.0,  256.0)
C:\>gdalinfo c:\arc_netcdf.nc
Files: c:\arc_netcdf.nc
       c:\arc_netcdf.nc.aux.xml
Size is 541, 421
Origin = (-70.600017600000001,41.199991170000004)
Pixel Size = (0.000833329999992,0.000833329999999)
Metadata:
  z_Layer#long_name=z_Layer
z_Layer#esri_pe_string=GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_
1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.01745329
25199433]]
  z_Layer#coordinates=lon lat
  z_Layer#units=Degree
  z_Layer#missing_value=-3.402823e+038
  lon#long_name=longitude coordinate
  lon#standard_name=longitude
  lon#units=degrees_east
  lat#long_name=latitude coordinate
  lat#standard_name=latitude
  lat#units=degrees_north
