[Gdal-dev] A feature request: add GEOS Is* functions to C-API
Brian Hamlin maplabs at light42.com
Tue Oct 16 04:30:44 EDT 2007
  in ogr.i:
IsEmpty(), IsValid(), IsSimple(), IsRing()
also AddPoint_2D()  and a bunch of overloads for SetField()
but, in the Perl bindings at least..
Is_Empty() is there, but Valid/Simple/Ring are not?
Move() is added
GetFeatures -> GetFeature
   and the detection of AddPoint() for 2D/3D
  tip of the hat to Howard Butler, for the original and continued work..
however, a simple perl script on trunk sources gives a runtime error
   IsEmpty() not found
for IsSimple(), IsRing() and IsValid()
   cant locate .../IsSimple.al in @INC(..paths..) at 'compile' time
geometry->Move() seems to work fine
-Brian
On Oct 15, 2007, at 11:41 PM, Mateusz Loskot wrote:
> Ari Jolma wrote:
>> IsValid, IsSimple, and IsRing from GEOS could easily be added to the
>> C-API ad bindings. In fact, I've done it locally since I need at least
>> IsValid. Is there a reason they're not in?
> Folks,
> Just to follow up this subject and keep users informed.
> The requested API has been exposed:
> http://trac.osgeo.org/gdal/ticket/1871
> I'd like to say Big Thanks to Hobu for cleaning this (and other
> tickets)
> during my absence last weeks.
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
