[Gdal-dev] Parameter names in swig bindings
Tamas Szekeres szekerest at gmail.com
Tue Oct 16 14:08:59 EDT 2007
Ari,
I don't see any problems with the perl builds out there. Could you
describe the issue in more detail?
Best regards,
Tamas
2007/10/16, Ari Jolma <ari.jolma at tkk.fi>:
> I assume there's no problem in changing the parameter names in the
> bindings? I'd like to rename the geom parameter to something else,
> probably spatialFilter.
> This because there's now a problem with the Perl typemap, which  says
> that  geom must not  be null (as is the case where it is used elsewhere)
> and in ExecuteSQL  geom is usually null.
> Ari
> Prof. Ari Jolma
> Geoinformaatio- ja paikannustekniikka / Geoinformation and positioning
> Teknillinen Korkeakoulu / Helsinki University of Technology
> tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
> Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
