[Gdal-dev] reproject a big ecw
Thu Oct 18 11:52:34 EDT 2007
SAEZ Laurent - CETE Méditerr./DI/ETER wrote:
> Hi,
> Thanks for you prompt response.
> The BIL file produced is about 37 Go.
> I'm going to try the same function with HFA format like you suggest.
> If this doesn't resolve my problem I will wait the next FWTools version.
> Frank, do you think that I should try to process gdalwarp without "--config GDAL_CACHEMAX 400 -wm 400" ?
Laurent,
I would at least suggest reducing the values you use, perhaps to 200 and
200.
The next FWTools will include the bug fix I referenced which *might* be
related.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
