[Gdal-dev] Null-Pointer in GDALOpen?
Mateusz Loskot mateusz at loskot.net
Mon Oct 22 11:00:28 EDT 2007
Tom Kazimiers wrote:
> Hello there,
> by playing around with GDAL I got some times the following error:
> Errorcode: 0xc0000005
> Erroradress: 0x011058a8
> Read: 0x00000000
> Looks like Null-Pointer for me.
> The code producing this is the following:
> GDALDataset *poDataset = (GDALDataset *) GDALOpen("a.tif", GA_ReadOnly );
> The file "a.tif" exists and I have openend it several times until it
> suddenly stopped working.
> I tryed with a SVN build from today and got the same results.
> What could cause such a failure in GDALOpen?
Tom,
First, you should always test pointer returned
from GDALOpen against null.
Have you tried to use full path to file?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
