[Gdal-dev] PROJ.4 warping string ignored
Seth Price seth at pricepages.org
Tue Oct 23 00:16:59 EDT 2007
Hello, let me first thank everyone for the great GDAL utilities. I've
been getting much use out of them. However I think I've come across
something of a bug. Some of my PROJ.4 parameters seem to be ignored.
Here is my warping command (note the -t_srs argument):
gdalwarp -t_srs '+proj=merc +latts=0 +lon0=0 +k=1.0 +x0=0 +y0=0
+a=6378137.0 +b=6378137.0 +units=m' -ts 11651 16480 -te
-10018754.171395 5465442.183323 -9796115.189808 5780349.220256 -wm
400 -co 'TILED=YES' -co 'BLOCKXSIZE=512' -co 'BLOCKYSIZE=512' -rc './
N046W090_x1.tif' './N046W090_x1.merc.tif'
I use the PROJ.4 library and these parameters and calculate that my
expected output bounds are the values I have for -te. However, the
output image is shifted, and results in quite a bit of black space at
the top of the image, and some cropped off the bottom. In fact, it
gives the same output image as this command would give:
gdalwarp -t_srs '+proj=merc +datum=WGS84 +units=m' -ts 11651 16480 -
te -10018754.171395 5465442.183323 -9796115.189808 5780349.220256 -wm
(note the different -t_srs)
It looks like most of my -t_srs isn't getting passed to PROJ.4. Am I
doing something wrong? Is this a bug in the package? If requested, I
can put the source file online, but it's ~300 MB.
Thanks,
Seth
