[Gdal-dev] ogr2ogr PostgreSQL and INTERLIS issues
Wed Oct 24 12:07:14 EDT 2007
Andreas Neumann wrote:
> Despite my flags "append" and "update" ogr2ogr is trying to create a new
> table. I get the following error message:
> ERROR 1: CREATE TABLE av."Bodenbedeckung__BoFlaeche" ( OGC_FID SERIAL,
> CONSTRAINT "Bodenbedeckung__BoFlaeche_pk" PRIMARY KEY (OGC_FID) )
> ERROR:  relation "Bodenbedeckung__BoFlaeche" already exists
> ERROR 1: Terminating translation prematurely after failed
> translation of layer Bodenbedeckung__BoFlaeche
> I know that this table already exists, but why is it trying to recreate it
> if I specify update and append?
Andreas,
This is because ogr2ogr does not find the existing table as a layer,
presumably because it is not listed in the GEOMETRY_COLUMNS table as
is expected for geometry based tables.
> * ili file required?
> In Interlis, the model is specified in the ili file and the data in the
> itf file. My assumption is that the ili file is only necessary in the case
> when I need to create a new data model/table structure and not for
> importing data into existing tables. Is this assumption wrong? When I try
> to omit the ili file, ogr2ogr crashes with the following error message:
> Segmentation fault (core dumped)
I'm a bit fuzzy on this aspect.  Pirmin is the authority.
But the crash seems like an unacceptable result, and I'd appreciate a bug
report on it.
> * temporary SQL files:
> My assumption is that ogr2ogr somewhere creates temporary SQL files that
> it is later feeding into PostgreSQL. Is that correct? Or is there a direct
> connection to the database and not temporary SQL file? If I can find these
> temporary SQL files I might be able to fix errors myself before loading
> the SQL files into Postgis.
It is done by directly submitting SQL statements to postgres through
libpq.  There is no file on disk.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
