[Fwd: Re: [Gdal-dev] ogr2ogr PostgreSQL and INTERLIS issues]
Mateusz Loskot mateusz at loskot.net
Wed Oct 24 12:12:07 EDT 2007
Andreas Neumann wrote:
> Hi Frank,
> thank you very much for answering my questions. I will contact Pirmin
> about the 2nd problem and file a bug.
> As to the first problem: the concerned table is listed in
> "public.geometry_columns" - but the table itself is in another schema,
> called "av". Could there be an issue when several schemas are involved? Is
> ogr2ogr fully schema aware?
Andreas,
Does the information included in the OGR PG driver manual answers your
question?
http://www.gdal.org/ogr/drv_pg.html
Cheers
Mateusz Loskot
http://mateusz.loskot.net
