[Gdal-dev] Building on OS-X
Christopher Barker Chris.Barker at noaa.gov
Thu Oct 25 14:46:08 EDT 2007
Hi all,
I'm trying to build on OS-X, and having a bit of trouble getting all the
libs it need found. So far, my issues have been libpng and libtiff, but
who knows what's next?
Which libs are others using? I had libpng already installed (from
source), but only the static lib, and Make was looking for *.dynlib, so
that didn't work.
So I've decided that I should just use the nifty Kyng Chaos-supplied
UnixImageIO framework. However, ./configure doesn't find it, so I
started doing things like:
--with-png=/Library/Frameworks/UnixImageIO.framework/Versions/A/unix/lib/
but that got ugly fast!
So, it appears that what I should do is add a --framework-UnixImageIO
somewhere, but I'm not sure where, as it's needed for both
pre-processing and linking.
Any thoughts?
-Chris
By the way, does autoconf have any facilities for looking for
Frameworks? It seems the ideal solution would be for ./configure to just
find it.
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
